Three improvements
Posted by: stuart on 14 December 2016
My current system consists of cd5xs,  ndac and 152 / 155 / flatcap xs. all Naim interconnects, 7.5m naca5, neat motive 2,  dedicated CU.  Components are on a home made rack with isolation spikes and chips (which made a noticeable improvement when changed from previous cheap av stand.
Room approx 5m x 3.5m. Speakers firing across room and I'm confident I've optimised position. Room seems well damped.
Have gradually upgraded from CD5i / Nait 5i,  speakers have remained the same (just like the song)
Overall I love the general presentation from a relatively modest system and I am amazed at how good it can sound.
There are three aspects that I have been trying to improve over the past 8 years
1. more refinement in treble frequencies
2. being able to follow bass lines more easily and better definition of bass eg between bass drum and guitar for example (I'm not requiring more or deeper bass particularly)
3. better separation of instruments on more complex tracks particularly at higher volumes (above 9 o'clock)
I am wondering if retaining my speakers and upgrading the electronics will improve these aspects or are the speakers at their limit?
I have considered numerous options but the one that currently is at the forefront of my thinking is to trade my amplification and speakers for a supernait 2 and maybe pmc twenty5 23s which my dealer stocks.
This would be about the limit financially.
Other considerations would be to trade all the electronics for 272 xpsdr and 250Dr whilst maintaining the speakers.
As a wild card I did consider merely adding a 282 and stopping there for financial reasons but I guess this would lead to an unbalanced system and leave me wanting more
I have demoed various speakers recently and pmc came out on top
Also heard the 272 xpsdr 250dr and was very impressed (but not with my speakers)
Further demos are in the pipeline (I do tend to take my time before committing to upgrading).  I have a great local dealer who offers great trade in deals for new and has been generous with home demos in the past.
Any advice would be greatly appreciated as I'm sure there are alternatives I haven't considered
Stuart
Posted on: 14 December 2016 by The Strat (Fender)
Do you wish to retain the CDP?  If so I would seek a 2nd hand XPS for the DAC and a 2nd hand 282/HC instead of the 152/FC.  Different NAP and speakers later.
Good luck.
Posted on: 14 December 2016 by stuart
I was set on getting started with streaming but the firmware update on the ndac has left me reluctant to offload it.  I'm quite happy with cd at the moment.
I would prefer to try and make a one off change rather than hankering after more upgrades over time (got more guitars to buy)!!!!
I guess there are always compromises to contend with until you reach the top which is out of reach for me and most I guess. The trick is getting to place where your happy to stop.
I've always been cautious about buying second hand but obviously many people do without any problems
Posted on: 14 December 2016 by Moussa
Hi Stuart
I can comment on your speakers with SN2. I used to own Motive 2 and they were outstanding drven by the SN2 and I enjoyed every aspect of the sound. I then had the opportunity to upgrade to the latest Motive SX2 and the sound got even better. The SX2 is a significant upgrade over the old 2. You get more transparency overall and more silky smooth highs in comparison with tighter bass.
Moussa
Posted on: 14 December 2016 by hungryhalibut
If you have such a great dealer, why not just spend some time there and decide?  It seems that you are after specific things that I never think about - do you actually enjoy music on your system at the moment? Maybe that's enough? Are you searching for a holy grail that doesn't exist? Will upgrading actually make you more satisfied?
Moussa posted:
Hi Stuart
Moussa
Thanks Moussa
I did consider the sx2 but thought it more of a sideways move. However you have obviously noted a significant improvement and they may well be worth a listen. I also considered the momentum sx3i but being rear ported I may have problems with placement.
Posted on: 14 December 2016 by tonycurran1
sn 2 with hicap is a great amp
to go for the 282 I would first go for CDX 2 if you can afford it use it with a XPS
i just picked up a ex dem CDX 2 for £3600 and a ex dem XPS for £3300
my next move will be the 282 + 250
my dealer has  a 282 for £3300
but until funds allow I will stick with my supernait 2 with hicap
i only got the CDX 2 and XPS yesterday evening so I am not expecting any vast improvement over my CD5 XS with hicap for a week or two.
Hungryhalibut posted:
Hi Hh
I have had a few demos over the last couple of months and will do more in the new year
I do really enjoy my system and like most of us am looking for improvements in certain areas that would enhance my enjoyment
I am totally realistic in terms what I would like and what I might end up with in relation to my budget. I recognise things will never be perfect but hopefully improved.
Having been in numerous bands since my teens I have developed the habit of listening to music in terms of what each musician is  playing and how they are plying it. This is something that is important but I'm not on an endless search for perfection.... I can't afford that!!
Yes, it's tricky when there are so many options. I just went for something on the basis that it would have no more than two mains leads, and didn't even listen to it beforehand. Then I got some secondhand speakers that are absolutely brilliant - I'd owned some before so knew they were good - added a few swanky wires and forgot about it. If you listen hard it will of course do your three things but is just so musical and enjoyable and I never even think about them.
You can overthink these things, and everyone will say something different and at the end of the day you often need to go on gut instinct.
Posted on: 14 December 2016 by Emre
Neat motive 2 were my first naim speakers and they were great, try them with 272 based system and 200s
272 is an VFM option or used 200s with hicap and then 272, cd will sing with ndac
Posted on: 14 December 2016 by hastings
Naim hiline = 1. refined treble + 2. distinct bass + 3. better separation
They're pretty cheap used.
I do think you should ultimately buy a proper equipment stand as well - Quadraspire racks are very good and rather affordable.  Strongly recommended.
Posted on: 14 December 2016 by Timo
Hi Stuart
If you like the Neat sound, I would stick with it. Personally I rather like the SX1 -- great soundstage and certainly a balanced sound with Naim. Down-firing ports make them relatively easy to position. I tried PMC -- the old Twenty and the new Twenty5 series -- great speakers too, but to my ears the treble is a bit harsh. I mainly listen to classical music, and something like Allegri's Miserere doesn't really work well with PMC....
Posted on: 14 December 2016 by NickSeattle
If I had your system and liked it as you say you do, and assuming you are running the CD5XS through the Naim DAC, I would try any of the Naim PSs on the DAC, or I would slot in a 202 or 282 on demo, to see if the effect is what I was looking for.  Sometimes it isn't, but the result is often positive in unexpected ways.
Nick
Posted on: 14 December 2016 by ChrisSU
It's always a bit tricky to decide where to make changes, in a system that looks pretty well balanced just now. If you want to make the move to streaming, I would consider swapping your CD player for an NDX, and playing that into the NDAC. However, you might first benefit from buying a NAS and starting to rip your CD collection, so that when the streamer arrives, you have at least some of your collection ripped and ready to go.
The other option would be to upgrade the preamp to 202 or 282, then you are likely to want to add a Hicap  (or change the 155 for a 200DR) to get the best from them.
Which of the 2 options works best for you is something you can decide with the help of your dealer.
It's also useful to consider the lifestyle choice - do you want six or seven boxes, or only two or three - as that may help in choosing the direction.
Thanks everyone
I have considered a new stand but I think my DIY rack isn't a bad effort.  obviously not as good as a commercial rack. I've always thought this would be one of the last purchases I made once I wasn't far off my end goal - to refine the sound even further.  This may be the wrong philosophy.
I've read numerous threads regarding the hiline in the past and considered its benefits better suited to higher level equipment. I may be entirely wrong and it would be easy enough to try one.
Initially my intention was to reduce the boxes but I'm happy with 5 shelves worth. Less would be OK
I've recently listened to a cdx2 as part of a demo and it is a great cdp but I didn't feel it was better than the 5xs with ndac
It would be great to move to a 282 but I can't help thinking I would then hanker after a 250 and it all becomes out of reach  as I do want to stop at some point - honestly?!
Also worth trying xpsdr for dac
I've tried to xp5 previously and didn't think it made a huge improvement.
Thanks again for all your suggestions
Posted on: 14 December 2016 by CharlieP
Stuart, can you post photos of your rack?  It might be really good or maybe not.  Tap on the rack shelf (glass on which component sits, for example) with your finger tip.  If the shelf rings (vibrates) at bass frequencies, then this could cause "mudyness" in the bass, and reduce articulation and separation of musical notes.  Also tap near one of the three supported corners of a shelf.  It should sound tight.  If there is any rattling, this can seriously degrade articulation, note separation, and make treble sound harsh - and the harshness will get worse at higher music volume.  What? Your rack doesnt have three point support or glass shelves?  Hmmmmm......
While putting an XPS on the DAC, as has been sensibly suggested, will potentially pay dividends in the three areas you seek to improve - these improvements will not be fully realized if you rack is misbehaving.
You have a good system, and it deserves a proper rack to deliver its best.  I hope your rack is already that good, but if it is not then it should be improved before investing in upgrades.  Perhaps you dealer could pay a house call and help you assess the situation.
Charlie
Posted on: 14 December 2016 by Adam Zielinski
Stuart - surprised no one has suggested this yet. You need 555PS (non-DR) on your nDAC. This will take your digital playback system to a completely new level addressing issues from points 1, 2 and 3.
Cost? Good, serviced examples can be had for around £2600 from a reputable dealer.
I'd say it would be lost on the amp and speakers.
Ahhh - yes - the amp - missed that part. Hmmmm...
SuperNait2 will work well, but that allmost calls for a HiCap DR. A lot of boxes.
To quote from The Police - 'every girl I go out with becomes my mother in the end'. Meaning - he really needs N272 + NAP250dr
Posted on: 14 December 2016 by ryder.
Certainly a difficult decision to make. Eventually any upgrade to a better source or amplifier will yield the improvements that you are seeking. For the three aspects that you intend to improve, they can be achieved by a source, amplifier or rack upgrade, or a combination of any of these things. From my opinion and personal experience, refinement in the treble is more toward the source, but it can be due to other factors as well such as rack, cables etc. Better quality bass in texture and definition and the separation of instruments, these are more toward amplification (pre and power). In the end it is the sum of the components that will contribute to the overall sound quality.
You can receive good recommendations as a guideline but eventually you will need to decide on the best option with your own ears, to be able to make the most cost-effective upgrade and get the best out of your money. I believe this is the goal for everyone. It is good to hear that you know what you want to achieve in your system with your given budget, and that a perfect sound does not exist.
A word on hifi racks. The system will surely benefit from a good rack and it's just a matter of getting the best out of your money, as usual. It's a subjective thing when it comes to the degree of improvement a good rack is able to bring to the system. Some say the improvements are massive, some feel the improvements are subtle, and some don't care at all. Case in point :-
Good luck.
ryder. posted:
That's the first photo I've ever seen on the forum where the amp is the right way round on the rack! (Shame about the speaker cables, though)
CharlieP posted:
Charlie, I'm struggling with the idea that you could ever produce a bass sound by tapping a small sheet of glass! I'm probably just being dumb and missing the point, but maybe you could elucidate?
stuart posted:
Moussa posted:
Hi Stuart
Moussa
Thanks Moussa
I auditioned the SX3i but they excited my small room 3x4m with bass. They SX2 bass is much tighter and engaged me more with the music. They just worked better in my room and I think momentum and ultimatum probably do better with power amps more so than integrated
ChrisSU posted:
ryder. posted:
The right way is the back? i dont get the picture, is the rack turned for photo purposes or something?  or .....  is it a "marriage ender", "instant divorcer", "siglematic" type of placement?
Stuart,
I think you are wise to do nothing, or go slow.
My experience is the 112/150/FC2X/CD5X was so much better than my excellent AV system that Naim won me over.  But, a 202/NAPSC was better into same.
IME, a better pre is always -- better.
Nick
