Problem with my "new" NAP200
Posted by: Vynz100 on 18 December 2016
Hello everybody,
Everything to my joy to have a NAC122X / NAP200 set, I want to test it ... and there the NAC122X does not turn on! I try again, I go back to my seller who graciously provides me with another cable, but still nothing ... the NAP200 lights up, "crac" usual in the speakers, but the NAC does not shake, nothing turns on. I check remote control and cie, nothing.
When I look at the NAP's 4 pin socket, I realize that the small metal end of "-ve" hole is not visible ... it would probably be the cause of all this ... how to remedy ? I do not know what I will do with the seller (well noted and who responds quickly to messages), or if changing this socket is complicated and expensive ... and I have no music! !! Thank you in advance for your advice!
