N272 power supplies
Posted by: deegee on 19 December 2016
currently trying a xps dr with my n272 and 300 dr, it is a improvement but not quite what I had hoped for. Would a 555dr be overkill for the n272?
In a word -no.
Only you can say whether it's worth twice what an XPS DR costs, but if the money isn't an issue for you, then it's probably worth trying. I haven't heard it myself, but from what others have reported about the effect of using a 555DR on pretty well anything, I would expect there would be a significant difference between the two power supplies on the 272.
best
Think I'll ask to give a 555dr a try, nothing to lose except alot of money if i like it!
I change my XPS-DR to a 555-DR on a 272/300 (non-DR) set up. TBH, the improvement was marginal.
Or you can try a pre-loved 555PS (non-DR). They come up for sale via reputable dealers - normally prices at around 50-60% of a new XPS.
deegee posted:currently trying a xps dr with my n272 and 300 dr, it is a improvement but not quite what I had hoped for. Would a 555dr be overkill for the n272?
I swear I wrote about this 2 months ago how ethier buy a 555PS or pocket your money because XPS doesnt do much
I had the same experience. I tried the XPS and it was meh, I can tell a bit of difference but it was marginal. Upgraded from a NAP-200 to NAP-250DR and the improvement was night and day. Going to listen to the XPS again now that i have upgraded amps, but so far the drawbacks of the extra box and extra expense to me outweighed it's marginal improvement in SQ. This was an XPS2, not a DR - so maybe the DR has a more significant impact as well.
Take care to install and "dress" the Burndy cable correctly to get the most from a power supply. It can make a big difference in sound quality. There is a thread in the FAQ.
Charlie
In my experience there's not a night and day difference between XPS and 555 (both non dr). If XPS offer a small and not worthwhile change, I would not spend nearly double price on a 555, (or a second hand non dr for that sake) believing it will do it for you.
S
Charlie,
What do you mean by install and dress the Burndy cable correctly?
jsaudio posted:Charlie,
See Adam's post in the FAQ: https://forums.naimaudio.com/to...a-bit-about-burndies
For the best results (the results you are paying for) with a power supply that uses a Burndy cable, the cable should be unstressed such that the connectors fit their respective sockets easily and free of torsional strain; the cable should hang freely without touching the rack, wall, floor or other cables.
Also, it is common for the sound of a device powered by an XPS or 555PS to continue to improve in quality after hook-up and power-on especialy the first few days or more. So take care in setup and be wary of first impressions.
Charlie
ps: sorry for taking so long to answer. This is a busy time, and my time zone is UT-8.
Thanks.
