NAXO-3
Posted by: skyebridge on 20 December 2016
I have acquired an old Naxo-3 (S/N 527x). The firm's records don't show much detail about how it was originally set up. It has never been back to the factory, but was owned for all it's life by an Audio Engineer. It looks pristine. Unfortunately, it's not suitable for use with my Ovator 600's, and can't be adapted (I was given some misleading advice about that - not by Naim, of course). My question is: Are these old Naxo-3's the same as, or very different from, the more usually found Naxo 3/6 etc?
Posted on: 20 December 2016 by skyebridge
Sorry: S/N 572x.
Posted on: 20 December 2016 by Richard Dane
The early NAXOs are very different. Naim were improving the NAXO all the time.  The first big change came with the extruded case that arrived in 1980.  Next big change was in '84 - the NAXO 3-6 had a completely different PCB layout IIRC, and also could take full advantage of the dual-rail supply from the Hicap.
Posted on: 20 December 2016 by jon h
and correct me if im wrong, but an ovator is a 2-way speaker not a 3-way, in terms of crossover?
and another change was the snaxo362 which could take burndy power from a supercap
and then the "floating" snaxo for the bmr S600 which is yet another entirely different design, using the sprung chassis ideas from the superline
