Russ Andrews X6: Any Experience?
Posted by: Timo on 27 December 2016
Seasonal Greetings!!
Recently. Simon-in-Suffolk reported some good results with a Russ Andrews' Mini Purifier and SuperClamp. Very intriguing... In Russ Andrew's current Winter Promotion, the X6 mains extension block fitted with a Silencer and SuperClamp is available at a reasonably good price. So I wondered whether the X6 was a worthwhile mains extension block upgrade. I understand that Russ Andrews offers a 60-day trial period (one would only be left with the return postage), but still I thought I better checked in the Forum whether there was any experience with this mains extension block.
Cheers!!
Posted on: 27 December 2016 by Loki
Funnily enough I am considering upgrading an old RA 4 way mains block to an X6. The current sale price looks very appealing. You have nothing to lose and, if my experience is anything to go by, much to gain. Their power cables are very good value too and you will need one to connect the X6 to the wall socket. Buy the best you can afford. They really do make a difference.
Posted on: 28 December 2016 by Timo
Yes, the current X6 price is tempting. A pity though that power cables aren't included in the winter promotion. For your possible X6 upgrade, do you have a particular power cable in mind?  Cheers!
