adding a qb with existing uniti qute
Posted by: crsm123 on 03 January 2017
Hi, I have a uniti qute and have just bought a muso qb. The set up says to add the the qb as a new room but I don't seem to find that in the app...
Thanks in advance for any help.
Richard
The units must be connected to the same network, preferably wired.
Tap on the top of the screen in the App - this is where rooms selection is done.
Thanks Adam. Now I can get to the rooms select menu - maybe an icon at the top of the screen would have helped ;-)
So now the app is searching for the mu-so and has been for quite some time.....
Not sure why it isn't found.
Ok, I sorted it now. The set-up guides on the naim web site a fairly useless. Only now having downloaded the QB user guide was the necessary information to connect.
crsm123 posted:Thanks Adam. Now I can get to the rooms select menu - maybe an icon at the top of the screen would have helped ;-)
Assuming your Muso QB has not been found I have few questions to start with:
- Are your both Naim devices and your tablet connected to the same network?
- Is your network 'running' a DHCP protocol?
- Can you stream or play iRadio from any of your UQ or Muso independently?
Adam
crsm123 posted:Ok, I sorted it now. The set-up guides on the naim web site a fairly useless. Only now having downloaded the QB user guide was the necessary information to connect.
Ok - good. Looks like you posted your answer when I was typing my questions ![]()
Enjoy the music!
Adam
Thanks for your time!
Cheers!
Richard
