Naim logo
Posted by: grahambateman on 14 January 2017
guys.
hope you can help.
i gave dac ,150 qwwx and flatcap.
All the naim logos are at different brightness  with 2 ire so amost dark. Is there a fix for this. Yes i know it's not a big problem bus cosmetically hmmm.
thanks
graham
Posted on: 14 January 2017 by JamesN
Hi Graham,
Funnily enough I have my NAP 200 booked in next week with a Naim dealer to have the logo changed to a less bright one so it matches my 202 and Hi Cap. Don't think it will be too expensive. I think they said around £40.
James
Posted on: 14 January 2017 by joerand
grahambateman posted:
I tried the Bing translator but it was no help. Interestingly, it detected your post as English.
Posted on: 15 January 2017 by Richard Dane
The early half moon logos were quite a bit brighter - too bright in fact, so this was toned down in around 2002 with the introduction of the new classic/ reference kit. Replacement logos are available to purchase via your Nsim dealer. You will need to ask them for the cost of logo and fitting.
Posted on: 15 January 2017 by HiFiman
My NAP100 logo is probably twice as bright as my 272
Following Richards post maybe all the old pre 2002 logos were dug out from the Naim basement and installed in the NAP100s
There will be some variance from model to model and to a lesser extent sometimes from sample to sample, but nothing like the difference between pre and post 2002, which is glaringly obvious.
Posted on: 15 January 2017 by bluedog
Richard Dane posted:
I see what you did there
