OK I'm going to buy a Raspberry Pi 3
Posted by: Bart on 14 January 2017
What shall I do with it? I was thinking of enabling a Pi > Hugo > SN2, as I'll be on the lookout for a good deal on a used Hugo just so I can hear it. Does that make sense? Any recommendations for software -- Rune perhaps? Then how do I control playback from an iPhone? And decent but inexpensive cables?
Should be a good 'winter project.'
If that is using Pi with rendering software to stream digital audio direct to the DAC, it begs the question what is the output from the Pi? If USB I would think it highly likely that you would need to isolate the Hugo to avoid defpgradation by RF, e.g. Using something like Gustard U12 as I used between Mac Mini/Audirvana and Hugo.
I was thinking idly about this earlier, and had a quick look.
You can get various add-on boards for them, several kinds of hifiberry, for example. At least one of those has galvanic isolation, I believe, and things to do with accurate clocks.
Going by Rob Watts' comments, I'd have thought optical would be a good choice into a Hugo.
If you go through with it, Bart, please let us know how you get on. I'd be kind of interested in doing it, but also kind of can't be arsed without a clear 'here's the idiot-proif list of things you need. And here's an idiot-proof list of what you need to do with each bit'. No pressure ![]()
Dave***t posted:I was thinking idly about this earlier, and had a quick look.
Frankly I'm hoping that someone here provides a clear list of things needed!
Well, I found something which might fit the bill.
A link would be against forum rules, but there's a guide by John Reekie called 'How to network your Mac music system with the raspberry pi and hifiberry' on the hifi zine website.
The title implies you'd need a Mac at the heart of the system, but after a quick read it looks like it could easily be made to work with, say, minimserver on a NAS.
I'm considering giving it a whirl just for a nerdy bit of fun.
I have a Pi1 and a Pi2 and use them for streaming (amongst other uses) via the home network.. I run minimserver on one and Asset on the other... works well into my NDX and other non Naim streamers... and I need no other attachments and no special operating system builds...all nice and simple.
Plenty out there on the web for this. I have 2 Pi3 one running Asset on Raspbian Jessie Lite with an HDD attached holding all my ripped music (FLAC) ... So basically using the Pi as a cheap low cost UPNP music server). That has been running for months with no issues. The second Pi I have played around with the main music based distributions (Volume, RuneAudio and Moode). They each have different features that you might prefer. I found Volumio to be the most reliable (and if AirPlay is of interest the one that works). This Pi feeds a Meridian Director Dac; the bedroom system.
Another option to play with given the rather nice kit you have might be to install Roon on a PC and use the Pi as a Roon Ready end point to feed music to the Hugo. I did install this and it worked (looked and sounded great). There is a 14 trial period.
There will no doubt be puzzles to solve playing with these, but Google is your friend.
I definitely contemplate using the Pi3B as a UPnP client for Minim or Asset running on a nas, to be connected to a Hugo. Whether the Pi can/should be connected directly to the Hugo with a simple usb cable is a concern.
Simon-in-Suffolk posted:I have a Pi1 and a Pi2 and use them for streaming (amongst other uses) via the home network.. I run minimserver on one and Asset on the other... works well into my NDX and other non Naim streamers... and I need no other attachments and no special operating system builds...all nice and simple.
HI Simon,
I seem to remember that you previously used a Netgear NAS. I take it that you have moved your music store to an external hard drive (or retain your music on the NAS, but no longer run media software on your NAS), and have replaced the NAS functionality with the Pi1 and Pi2 units. If this is the case, could I ask you why you have done this? Did you do it simply for curiosity, fun or were you of the opinion that it might improve your streaming sound quality?
Has this resulted in any detectable improvement?
Hmack - no I moved from Asset and MinimServer to predominately use my Netgear NAS and its inbuilt ReadyDLNA media server - it sounds better and I can see a definite difference on the wire which may account for the SQ difference.... however I keep the Pi's going for DSD and for beta testing - and they work well hence my comment to this thread..
Simon-in-Suffolk posted:Hmack - no I moved from Asset and MinimServer to predominately use my Netgear NAS and its inbuilt ReadyDLNA media server - it sounds better and I can see a definite difference on the wire which may account for the SQ difference.... however I keep the Pi's going for DSD and for beta testing - and they work well hence my comment to this thread..
Any experience or recommendations using the IPi as a client?
Simon,
are you using FLAC or WAV files on the ReadyNAS? I switched to asset on a PI to enable on the fly translation to WAV, which is not available on the ReadyDNLA, at least not my version.
I must do a side by side comparison.
Bart posted:I definitely contemplate using the Pi3B as a UPnP client for Minim or Asset running on a nas, to be connected to a Hugo. Whether the Pi can/should be connected directly to the Hugo with a simple usb cable is a concern.
If you use the appropriate hifiberry board (digi+ transformer version), then there should be no problem using USB into a Hugo. The issue otherwise would be electrically noisy USB, as the Hugo isn't isolated. But that version of the digi+ is.
But why use USB? If you're going to use a hifiberry board at all, then into a Hugo I'd say you're better using optical rather than USB. That's what the designer of the DAC recommended, and it removes any electrical noise issues. In that case, the digi+ pro would probably be better, as it has more sophisticated signal clocking.
If you don't want to use a hifiberry board for whatever reason, I've no idea. They looked good, so I've concentrated my reading up around them.
Dave***t posted:Bart posted:I definitely contemplate using the Pi3B as a UPnP client for Minim or Asset running on a nas, to be connected to a Hugo. Whether the Pi can/should be connected directly to the Hugo with a simple usb cable is a concern.
I hadn't gotten as far as deciding on a hifiberry board (which includes optical toslink) or not. It seems that for use as a UPnP client into a dac it's the right hardware.
Following this thread with great interest as I wondered about the Raspberry Pi as a project.
If it's a matter of just wanting an economical front end for trying out a Chord DAC, I struggle to see why a Pi would be better than a Chromecast Audio. The CCA would be cheaper, too.
But as a project, it could be fun. Some people have really gone for it with toroidal transformers, full size hifi cases, touch screens etc. But a fairly basic setup would still be a good afternoon's tinkering.
For me it's at least as much as a project. Just something I want to do / learn. Some tinkering as you say. And I can combine it with hearing the Hugo in my home if/when I find a used one cheap enough. And I can figure out other tinkerings with it; there are a zillion useless things one can do with it.
David posted:Simon,
David I use FLAC and WAV, as ReadyDLNA doesn't transcode - I also feed a Hugo from the NDX - and this way the difference between FLAC and WAV is very minimal and certainly not distracting in the way it is when I have used the NDX's internal DAC
Bart posted:Simon-in-Suffolk posted:Hmack - no I moved from Asset and MinimServer to predominately use my Netgear NAS and its inbuilt ReadyDLNA media server - it sounds better and I can see a definite difference on the wire which may account for the SQ difference.... however I keep the Pi's going for DSD and for beta testing - and they work well hence my comment to this thread..
Bart - no - I have only used the Pi as UPnP media server over the network.. - it also mounts the NASs over the network..
Dave***t posted:If it's a matter of just wanting an economical front end for trying out a Chord DAC, I struggle to see why a Pi would be better than a Chromecast Audio. The CCA would be cheaper, too.
The CCA doesn't do gapless playback, so that's a reason to go for a Pi.
Bart posted:For me it's at least as much as a project. Just something I want to do / learn. Some tinkering as you say. And I can combine it with hearing the Hugo in my home if/when I find a used one cheap enough. And I can figure out other tinkerings with it; there are a zillion useless things one can do with it.
There's nothing to stop you trying out a Hugo or other Chord DAC without doing anything other than obtaining an SPDIF cable that may need to be BNC to RCA and possibly needing to obtain a cable suitable for the DAC's output into your preamp, and indeed trying direct into powervamp,if you wish (Hugo or higher)
Pi would complicate trying Hugo for DAC trial purposes, as its quality would be unknown. But as a basis for setting up a uPNP server, or a home-made NAS, or if rendering software is available, it is a an inexpensive and accessible tool to experiment with, and learn while at it, with little to lose if it doesn't work for you in the end.
The Pi reminds me of the Sinclair Mk14 kit computer back in the 1970s, though a tad more powerful and versatile: IIRC my brother's Mk14 had 0.5 kB of RAM, machine code programming with a hexadecimal keypad, a 7-segment calculator-style LED display, and no non-volatile memory. And with an external board with an additional 0.5 kB he claimed it was so in demand at university that he could swap for someone else's girlfriend for the night (But I have no idea if that deplorable behaviour was true!) The whole point of it was to learn about computers, and get it to do things. But Pi has rather more capability!
Look at dietpi if you get a Pi. It simplifies installs and has a pre-defined set of audio programs to install which cover most bases.
.SJB
Innocent Bystander posted:There's nothing to stop you trying out a Hugo or other Chord DAC without doing anything other than obtaining an SPDIF cable that may need to be BNC to RCA and possibly needing to obtain a cable suitable for the DAC's output into your preamp, and indeed trying direct into poweramp, if you wish (Hugo or higher)
Yes I can appreciate that if I want to "hear" the Hugo, pairing it to a Pi may result in me hearing the Pi AND the Hugo. My NDS has a BNC digital out; I think I could use a DC1 BNC to BNC cable to connect the NDS to a Hugo, and then connect the Hugo to my SN2. That's probably the right way to hear JUST a Hugo, correct?
I'm still going to play with a Pi
I don't know about Hugo 2, but Hugo uses rca not bnc for spdif. Suitable cables are readily available, quite inexpensively, though when I had an ND5XS it came with a bnc-rca adaptor, which would allow use of an rca-rca cable, though it should be a 75Ω ("video") cable. If the NDS has an optical oiputput you could use that insread.
output of Hugo is rca.
Innocent Bystander posted:If the NDS has an optical output you could use that instead.
Thanks; NDS only has a BNC digital output.
Well, if you go through with it Bart, it's begging for a comparison between NDS and Pi into a Hugo, as well as an audition of the Hugo itself.
No one would expect to see your NDS on the market shortly afterwards, I'm sure, but it'd be interesting to see how close the little fella can get.
Bart posted:What shall I do with it? I was thinking of enabling a Pi > Hugo > SN2, as I'll be on the lookout for a good deal on a used Hugo just so I can hear it. Does that make sense? Any recommendations for software -- Rune perhaps? Then how do I control playback from an iPhone? And decent but inexpensive cables?
Bart, just install plain Raspbian, it is the best distribution for the Pi. In a nutshell, you do:
1) download Raspian Jessie Lite from https://www.raspberrypi.org/downloads/raspbian/ and follow https://www.raspberrypi.org/do...ing-images/README.md to copy the image on a micro SD card. Do not use a large card. 16GB is more than enough and will allow you to make an image of your card (for backup purposes) in a few minutes.
2) Next, put an empty file named "ssh" in the boot partition of the micro SD card. Insert the card in the Pi and connect it to your router or switch through an ethernet cable. Connect to the power. Log in via ssh from any computer connected to your LAN with user "pi" and password "raspberry". You'll need to get the IP address of the Pi from your router, of course. You do not need to fiddle around with keyboard, mouse or monitor: just setup your Pi remotely.
3) Install MinimServer on the Pi following http://minimserver.com/install-raspbian.html. This is a great pleasure, the documentation is simply perfect. If you want your Pi to also work as a renderer (directly connected to a stationary USB DAC, to a USB to SPDIF bridge or to a portable DAC + headphone amplifier for playing music on the go) with support for TIDAL and Qobuz, install upmpdcli http://www.lesbonscomptes.com/upmpdcli/index.html. If you want to setup you Pi as an access point (very useful if you want to create a private network, for instance, for straming on the go on in a situation in which you cannot or do not want to rely on an existing LAN infrastructure) follow https://www.elektronik-kompend...berry-pi/2002171.htm. The text is in german but the installation steps are self evident.
You can add up to 1TB of memory on mSATA drives, SD card or external SSD or PiDrive. For enclosures for the PiDrives, check http://wdlabs.wd.com/category/pidrive-enclosures/. You'll get the smallest package with a mSATA adapter and a Pimoroni enclosure:
Best, nbpf
(Edit: you can control playback from iOS or Android devices with Linn Kazoo or any other control point. You can stream from the Pi to local renderes on mobile devices with Air Player (iOS), VLC (iOS and Android), Bubble UPnP (Android) ...)
