what kind of files can be played on DAC by memory stick
Posted by: comickitkit on 08 August 2011
Dear Friend,
I tired AIFF file on DAC via memory stick, but it just doesn't work.... +___+
so what kind of files supported in DAC by memory stick?
and does every kind of memory stick sound the same in DAC??
Posted on: 08 August 2011 by sheffieldgraham
I assume you are referring to the Naim DAC. If so the USB ports support WAV and if you have the latest firm wear FLAC also. As far as I'm aware they do not support any other codec.
Can't comment on best sounding memory stick. I've only used HP thus far, which I'm happy with.
                  Graham
P.S. Here's a link to the DAC firmware update. Enables FLAC replay via USB. (previously WAV only).
http://www.naimaudio.com/userf...software_update.html
If you are unsure how to update contact Steve Hopkins : support@naimaudio.com
