Best MM Phono Stage.
Posted by: DUPREE on 20 January 2017
I am looking to upgrade my Phono Preamp. I am using an inexpensive Project Phonobox S, and I will say it punches above it's weight, is very versitile and I like it, but it is not getting everything I think I can get out of my table, although I am estatic at the sound of it currently.
My current system is NAC-N 272, NAP 250DR, Linn LP-12 (Cirkus/Ekos2/Lingo2/Trampolin2/Adikt/Funk Firm Achromat, Project Phonobox S),Linn Majik 140, Synology 1515+, NACA5, Grado PS500e.
I have two that I am somewhat currious about that I have heard a lot of buzz around - The Graham Slee Accession and the Lejonklou Slipsik. I have heard the Slipsik is the best MM stage made whether that is true I have no idea, The Graham Slee Accession is priced exactly the same and is a bit more flexible with various EQ levels and mono which I am not 100% sure I will use but sure sound handy with older records.
Anyone have an opinion on these or another recomendation? I would consider the NAIM, but it does not wind up being a good solution with the 272 because it is not self powered and requires a PS that is more expensive than the pre itself. I wish they would come out with a good phono solution for their new gear like the 272.
