Strange glitch in music
Posted by: Tom-in-Amsterdam on 26 January 2017
The new system plays great..., but some recordings...are really awful!
Last night, I thought I was getting crazy. There is this intermediate clicking / glitch in certain recordings. Also, you can hear a bit of grain from time to time.
Song in which I can reproduce: Goldfrapp - Jo, 30 seconds mark.
At first I thought the Hugo was to blame. But having listened using Audirvana and JRiver Mediacenter the same glitch is there. Switching to headphones directly on the mac, same thing. Switching to Spotify to eliminate source problems, same thing!
Then switched to Spotify on my iPhone, same thing! It's as if the recording was mixed poorly when you listen carefully.
Can somebody verify / explain?
I've been listening to Jo - in fact it's on now - and it's perfect - no glitch. Maybe there is a fault in your rip.
You have eliminated your system as the cause, to your ears, it's also present on Spotify, HH has eliminated the master as the cause - there's two things remaining that are common all instances of the clicking / glitch ...
Your ears and brain! ![]()
On the Jo track there is annoying click on the left channel, but this is clearly in the recording / master and follows the timing of the beat. If the timing was irregular it would certainly sound very similar to a digital glitch. A studio engineer probably thought it added something, which it does, an annoying click on the left channel.
SongStream posted:On the Jo track there is annoying click on the left channel, but this is clearly in the recording / master and follows the timing of the beat. If the timing was irregular it would certainly sound very similar to a digital glitch. A studio engineer probably thought it added something, which it does, an annoying click on the left channel.
Yes, I can hear that click as well and that was / is irritating as well. I did listen again now using my headphones on my imac and sure enough there is a glitch at the 30s mark when she starts singing "what If..."
However, when I listen to it without my headphones and use the cheap computerspeakers attached everything is fine.
Hungryhalibut posted:I've been listening to Jo - in fact it's on now - and it's perfect - no glitch. Maybe there is a fault in your rip.
Thanks for testing. I suspected a faulty rip as well, but I can hear the same thing in Spotify, on exactly the same mark. Maddening
I didn't hear anything annoying - maybe my ropey old speakers are insufficiently resolving.
Huge posted:You have eliminated your system as the cause, to your ears, it's also present on Spotify, HH has eliminated the master as the cause - there's two things remaining that are common all instances of the clicking / glitch ...
Yes indeed! And I trust my ears... now for my brain, that's another!
What keeps bugging me though that over Christmas we had a few friends over and drank way too much wine. Late in the evening one of my friends pointed the same thing out to me. I wasn't able to dig in at that moment and forgot about it until last night (probably triggered by all the new boxes). I'm pretty sure I have heard it in other recordings as well, but dismissed it so far. Probably best to leave it as it is (but annoying nevertheless!).
I'll have a listen later - i downloaded my copy so will see if this does the same as noted above.
I've just listened again and there's nothing untoward at all. Maybe I need some Majik 140s.
maybe it's your 272 HH ![]()
Hungryhalibut posted:SongStream posted:On the Jo track there is annoying click on the left channel, but this is clearly in the recording / master and follows the timing of the beat. If the timing was irregular it would certainly sound very similar to a digital glitch. A studio engineer probably thought it added something, which it does, an annoying click on the left channel.
Well, I was listening on earphones in my office, so maybe its more noticeable via such a medium. I'll try it later on my blurry Proacs out of curiosity and see if its noticeable / annoying with them. Despite the fact that it does start at around 30secs into the track, it appears it is not what the OP is referring to anyway.
analogmusic posted:maybe it's your 272 HH
Maybe it's those pesky overpriced Ethernet cables. The clicks just can't get through.
I can hear it as well, even before the 30 second mark.
Tom-in-Amsterdam posted:Hungryhalibut posted:I've been listening to Jo - in fact it's on now - and it's perfect - no glitch. Maybe there is a fault in your rip.
Faulty Rip?
I don't know much about Streaming, but had the same problem with my Cdx2.
I eliminated my System by playing the same CD on my MM Super Drive, my ripping device.
Hence, the culprit was my Cdx2, 2 months later skipping gone, New 1202 VAM !
I was hoping, these types of glitches weren't present, in the world of Streaming.
Might be a stupid question, but is it possible for you to play the same tune on your ripping device?
Trying to gain insight into the World of Streaming!
Allante93!
Just remembered to give this a play when i got home.
I can hear it as the two synthesised piano notes fade up - starts at about 23 seconds on the louder of the two notes and continues through the track. Hadn't really noticed it until you mentioned it but it's just part of the track and doesn't spoil what is a pretty decent recording.
James
james n posted:Just remembered to give this a play when i got home.
James
Same here, played via SN2 and Proac D18s the click is audible, but much less emphasized than it was through the earphones I was listening with earlier, which are nothing special and quite thin sounding by comparison. With the richer sound of the Naim / Proac combo I doubt I would have really registered it. Good thing is, I've never listened to this album before, and I quite like it, so its still going and I agree the recording is rather nice when played properly.
Yes i carried on too ![]()
Nice track - Must explore more Goldfrapp.
I'll be exploring further too. I've been having a serious binge on Agnes Obel of late, and this album blends in with that quite well. When I think Goldfrapp, I think of the Supernature album, which has its qualities, and I like it, but it is the only Goldfrapp album I'd previously listened to, and is very very different to the album in question here.
James
Yes, I can hear that, it's almost like part of the piano sound, sort of mechanical. It's clearly just part of the recording.
Tom, just enjoy the music and stop looking for faults. Everything is fine.
Hungryhalibut posted:james n posted:Just remembered to give this a play when i got home.
James
Doesn't sound 'mechanical' to me; must be my uncomplicated network switch that's the issue.
Good advice.
Tom, sounds like it's the recording at fault but could I suggest one simple inexpensive thing for you to try? A Sys Concept 1300 strand optical cable connecting your Mac Mini to Hugo. Order direct from Sys Concept in Canada, its only a few quid and might help with that 'grain' you describe. Worth a try because it will isolate your Hugo 100% from any rf noise from Mac Mini that might be causing the 'grain' and you can skip/sell the Gustard if you prefer it.
Can confirm glitch. But this is "electronica" after all. Many recordings have grunge programmed in. Don't forget the Trip Hop years when everything had some rumble, wow, flutter and fluff present.
A gestalt artefact to bring awareness of the vocal just coming in after perhaps, or an emulation of snare springs reacting ?
Does this mean we can now discount HH's opinion on subtle sound quality questions? ![]()
