Posted on: 05 February 2017 by Chag...
You might want to switch the nDAC off, switch it back on again and check whether the firmware has really been updated to v.4.11.8 yet. If not, I would follow the instructions all over again and use another memory stick that you will have tested by playing a WAV file.
I happen to have conducted the update only recently as I wanted to take the time to compare pre and post v.4.11.8 against NDS v.4.3 and v.4.4. The update went very quickly - in less than two or three seconds. Lights went on again during automatic reboot as to confim that version 4.11.8 was installed, but lights 1 and 4 eventually stayed on. I used the Display button of the Narcom 4 in Pre mode to switch them off and checked again the version installed. v.4.11.8 was confirmed again. I then checked whether it could play a few Podger's L'Estro Armonico DSD64 tracks and it did it very very well. I was happy. I hope it eventually will go as well with your update.![Dan.San :]](http://synthese-hifi.com/phpBB2/images/smilies/8.gif)
Chag -
