Chord Shawline, 5 Pin Din to 5 Pin Din Audio Cable SKU: Shawline 5 Pin Din to 5 Pin Din Audio Cable
Posted by: tonycurran1 on 06 February 2017
hi saw your post this morning before going to work
had a 5pin to 5 pin interconnect in its box since getting my system about 2 months ago
plugged it in before going to work as the cable as never been used before between my NDS and supernait 2/ Hicap came home this evening had a listen to 4/5 tracks and was very impressed with the way it opened up the top mid and bass
my speakers are MA 8 silver
Posted on: 06 February 2017 by Kacper
My experience are the same with shawline, I have arranged with Nordost dealer- I will be able to try at home heimdall 2 (din to din) before any purchase. I'm very excited about those two opponents.
Posted on: 06 February 2017 by tonycurran1
I use cord epic speaker cables as well don't know if keeping the cables from the same brand will make a difference.
With some cables perfect match is when they come from the same company even the same line.
Posted on: 07 February 2017 by Salmon Dave
I've been using a Clearway digital I/c - excellent. One of Chord's advantages is the development they've done on their (RCA) plugs in recent years.
Posted on: 07 February 2017 by Wals79
I too use all shawline cabling and epic speaker cable and think its fantastic for detail i noticed a marked improvement over the Lavender din supplied with my Naim kit
Posted on: 09 February 2017 by Kacper
 Unfortunately  won't be any trial of the heimdall 2 probably. Dutch distributor of the nordost products pointed the shop where I could collect the cable ( kind of drop place) where service it's so bad that I could go for it. Disgusting staff !
