Using a MuSo as a sound bar??
Posted by: Victorthesecond on 10 February 2017
HI everyone, I wonder if I might ask for your views on a very simple question?
Can I connect my MuSo directly to my TV to act as a sound bar?
The TV has HDMI and Optical connection options - if I use an optical connection, do I literally select the "Digital" button on the MuSo app to make it work? It seems too simple......!
Thanks in advance for replies
Mike
Posted on: 10 February 2017 by Timmo1341
Yes is the answer! I have a JVC tv connected to Muso via optical lead. Simply select the TV setting in the App, or digital on rotary control (right hand of the 3 'segments') and away you go - superb sound quality. Just make sure you're outputting the tv sound in stereo, not Dolby 5.1 or anything esoteric, as the Muso only accepts plain vanilla stereo.
Posted on: 10 February 2017 by Victorthesecond
Great, thanks for that! I have no TV option in the app though....only one that looks good for this is "digital"....Am I missing something??
Or will a TV sign magically appear when I connect the two (That might be too easy!)
Victorthesecond posted:
Sorry - I forgot to say I renamed 'digital' to TV!!
