One stack of Fraimlite or two stacks of...?
Posted by: AI17 on 13 February 2017
This is my first post so please be gentle!
I have followed the forum for a long time as I have gradually upgraded my Naim system and have learnt a lot from you all about how to set things up. I currently have my components on a single stack of Fraimlite. I noticed an improvement moving from an older glass and steel AV stand. Following advice from the forum I have also experimented with stacking order which has also improved things. Now I would like to optimise my system further and moving to two stacks separating brain and brawn seems to be the way to go.
The simplest thing would be to buy another Fraimlite base and move two shelves on to that but it would mean my interconnect would be on the floor if I had NDX & 252 on brain side. Two stacks of full Fraim is too much right now. This has got me wondering about other options...
I'd be very grateful for opinions on:
1. A new base and moving to two low stacks of Fraimlite (would this be an improvement despite the I/C touching the floor?)
2. Moving to two cheaper stands with bigger gaps between the shelves (Quadraspire? Isoblue?). I can't demo these where I live. If anyone has compared I would be grateful for opinions on whether this would likely be better or worse than one stack of Fraimlite with standard spacing.
3. Stick with one stack and add some full Fraim e.g. under the NDX/252.
4. Something else?
System is: NDX, XPS-DR, 252, SC-DR, 250-DR, NACA5, ATC SCM19, powerlines, SL I/C
