names of naim
Posted by: wiwa on 20 February 2017
has the terms like nac, nap, nds, ndx, nait a specific meaning and forwhat they stands?
Posted on: 20 February 2017 by Ron Toolsie
Naim Audio Control (preamps), Naim Audio Power  (power amps ), Naim Digital Streamer,   Naim Audio InTegrated. ...the X is a little less intuitive. ..it is usually applied where there is extended performance over a predecessor. .I think the Flatcap 2X was the first example. ..the XS probably have similar connotations. But that doesn't really explain the HDX. ..although the Hard Drive bit is easy enough. Sometimes a Name is just a naim.
Posted on: 20 February 2017 by james n
Ron Toolsie posted:
Hard Drive eXperiment
Posted on: 20 February 2017 by wiwa
thanks
Posted on: 20 February 2017 by Mario
An X in the name usually implies hat the product can be upgraded with an X - eternal power supply.
Mario
Posted on: 20 February 2017 by Salmon Dave
Nah.... the first 'X' was the CDX in 1998 or 99. So named as the previous two midprice integrateds were the CDI (CD Integrated) (not CD1) and the confusingly named CD2.... then the more budget CD3 came along so Naim decided to avoid further confusion with the CDX (I suspect). The NDX was perceived as the Network equivalent.
Excuse me, I'm popping off to listen to my Rega system....:-)
