Help finding Progrock.com 192 Kbps
Posted by: nitrous on 21 February 2017
Folks, I heard the DJ mention progrock.com now broadcast in 192 as well as 128. Try as I may I can only find the 128 stream in iradio on 272. Anyone know who to get it to pick the better stream up?
cheers.
Posted on: 21 February 2017 by jon h
as an aside, i wish marillion would make their recordings available in hidef -- i have looked but not found anything, unless anyone knows better?
Posted on: 21 February 2017 by lola20124
It is on shoutcast.
Posted on: 21 February 2017 by nitrous
[@mention:47323795857559624], how do I get 'shoutcast' on iradio/272 please? In fact, what is shoutcast?
Posted on: 22 February 2017 by Dave***t
If the higher quality stream doesn't show up in the iradio menu on your 272, you may be able to add it manually by going to naim.vtuner.com
To do so, you'll need the stream's address, which the station should be able to provide if you ask them.
If you are able to add it that way, it'll then appear under 'Added stations' in the Naim app.
If you struggle with the above, I'm sure Naim support will be happy to help.
Posted on: 22 February 2017 by nitrous
Cheers Dave, will try that and see how I get on.
Posted on: 22 February 2017 by BigH47
Progressive Rock files are available @192.
http://www.thedividingline.com/tprf.html
