Hi all
I am about to upgrade my system from low end Rega to Naim and thought I had it all sort of sorted... Now I'm questioning some decisions given the starting outlay and the Naim route it sets me off on. My dealer, Pure Hifi (Bruce and Carey) in Christchurch NZ have been superb and I will be discussing my thoughts there, but welcome your opinions on this.
Objectives of the new system - Playing Vinyl and streaming / playing FLAC files. Box count not important.
Streaming - probably mainly tidal (I don't currently) but I enjoy the discovery process on bandcamp and buy most of my vinyl & FLAC there for a portable FIIO X1 that got me started on the whole system reassessment.
Vinyl - to enjoy the old and new and keeping my current Rega RP3 with a new Rega Exact cartridge and new-S/H Naim Stageline
For the last 18 years I have enjoyed a Rega Clamshell Brio, Rega EL8 speakers and RP3 as the main source with occasional laptop, iPhone and latterly Fiio X1 connected for digital files. So I first off needed convincing that the Naim sound would well exceed the enjoyment I had out of the Rega set up. I started by listening to a UnitiQute & Rega RS1 speakers, with the thought that this would replace the Brio, do the streaming job and could accept the RP3 with a stage line. This was probably an improvement but it didn't give me the jump in sound quality or engagement with the music I was looking for. So Pure Hifi suggested the ND5XS and Rega Elicit R vs Naim Nait XS and I suggested that floor standing RX5's were more the type of speakers I liked the idea of, so these were listened to, against some ProAc 140MKII's which were old stock being sold at an attractive price at the time.
The result of the Demo was the Naim ND5XS - NaitXS combo won out quite remarkably from the Rega ElicitR and I ended up buying the ProAc speakers as they will give me a system that sounds in a different league to the previous Rega system and that was the first objective satisfied.
In the next couple of months I will be starting my Naim investment and realise that I have ended up with an Integrated solution without considering a Pre/Power starting or upgrade route. I am quite likely to make this system upgrade and stick with it, getting on and enjoying the music and other pursuits, rather than starting an incremental upgrade route... That said this may be a two stage upgrade with an interim second hand component being replaced later with the 'final' piece.
So to the question in the title setting aside the streaming qualities that I have found covered in other threads, with a Rega RP3 & Stageline source is there a reason to direct me down either route - ND5XS / NaitXS2 or NAC N 272 + NAP200 (maybe second hand to upgrade to NAP250DR later)
Obviously I'll be looking to do some listening to the Streaming Pre/Power option vs the Integrated, with the RP3 to see if my gut feeling of that the NAC N + NAP is the way to go, but look forward to hearing your thoughts / experiences of each.
thanks in anticipation.
Posted on: 25 February 2017 by Emre
i am an unhappy user of stage line with flatcap2 - or unhappy user of EAT C-Major/Ortofon Quintet Blue MC not sure which one or all...
272 digital is "same" , in almost every record
where is the " analog " sound ? i played good Blue Note 45s as well...
I like the Naim sound very much but stage line + a power source (you need one with 272 ) makes it a poor value in my opinion...also +1 cable 4/5DIN
So maybe a 272/200 and a rega aria to keep thing less sophisticated... maybe even better sounding
Posted on: 25 February 2017 by Huge
I had a ND5 XS + Nait XS, then upgraded the ND5 to a 272 (while still using the poweramp of the Nait - that was a big upgrade. Using a 272 with a 200 or better still a secondhand 250DR will be better still. I currently use the 272 with a 300DR (and an external PSU on the 272) the result is superb in every way I can think.
I would wholeheartedly recommend the 272 route, particularly if you can upgrade the poweramp and 272 PSU at a later date; the 272 is capable of keeping up with some very high quality gear - indeed Naim consider the 250DR it's natural partner, it's that good.
Also don't worry about the analogue preamp side of the 272, that's also way better than the XS preamp.
Posted on: 25 February 2017 by Foot tapper
Hi Holmes,
The ND5 XS + Nait XS + Proac 140 Mk II does have to look of a balanced system. More importantly, you have heard it and like it. So, I would only go for an alternative if you can audition it first. Be wary of making a leap that appears great on paper unless you can actually hear it for yourself. This is where your dealer is invaluable.
When considering pre-power options, the question of budget is an important real world consideration. A 272/250DR should sound absolutely marvellous with your Proacs. However, how many times more expensive is it in NZ than the ND5 XS + Nait XS? Perhaps a more comparably priced alternative might be a 272/NAP100? Our modest old NAP140 power amp can drive Proac 140 speakers fine and is surprisingly close to an olive NAP250 in that respect, really only losing half an octave of deep bass and its ultimate control. So, if you go down this path, put the money into the pre-amp rather than the power amp.
Each option will need a separate phono stage. You could do a lot worse than to use a Rega phono stage with your Rega RP3. The Aria is really excellent and should last you a lifetime of upgrades up to and including an RP10 and Alpheta 2. It does cost more than an RP3 though!
A classic Naim alternative might be an ND5 SX, plus 32.5 (or 72) with internal phono cards, a hicap and a NAP140. If your dealer happens to have one of these, then this would give you an affordable, future proofed and depreciation proofed pathway to musical heaven!
Happy auditioning, FT
Posted on: 25 February 2017 by joe9407
yes, the Rega Fono should be fine -- but for a little more dough, the OP could have a Dynavector P75 phono stage, which would be fantastic and see him through any future changes he might wish to make WRT his turntable.
i too think that a 272 + a s/h amp is the way to go. a (non-DR) 200 or 250.2 can be had for reasonable money and would put those Proacs through their paces!
Posted on: 25 February 2017 by Mulberry
Hi Holmes,
you already have the Stageline, right? If you take the pre/power route, think about the power supply to get it going. The 272 cannot power the Stageline, a 202 or 282 could. A Flatcap or Hicap would do the job as well.
How about the NDX and SN2? Both are one step above the XSes in the lineup. If your dealer has these two, give them a try. And the SN2 can power the Stageline.
The most important thing is to listen and trust your own ears.
Posted on: 25 February 2017 by Holmes
Thanks for all the replies.
I will certainly review the choice of stageline as the phono amp, it's part of the system that I thought was an easy decision with the rest being Naim. So I will demo the Aria / Fono / Stageline for sure, as that seems to keep the 272 route open cost wise.
Emre - What's your amp / speaker combo, that gives you disappointing results with the stageline?
Foot Tapper - Good point, the system I've heard is good and a bird in the hand and all that. If I go 272 it probably means second hand power amp for now so I'll have to see what I can listen to before taking that path.
Mulberry - Adding a power supply is cost prohibitive right now. It seems folk leap the SN2 when upgrading from a NaitXS
Huge - Did you consider upgrading the ND5XS to NDX / SN2 ? before going 272?
Posted on: 25 February 2017 by NickSeattle
FWIW, when I got into Naim with a 112/150/FX2X, for my existing 2000-ish Planar3/Elys, I preferred the Fono to the StageLine.
I upgraded the Elys to Exact a few years ago, and bought a second hand Aria last month, mostly so I can experiment with MC and, possibly, a TT change.
All the same, the Planar3 continues to please -- so much better than my old Beogram 2000, and idler-Duals of old. The VFM is hard to beat.
Nick
Posted on: 25 February 2017 by joerand
I have a 1985 Rega Planar 3 which I have regularly serviced
What exactly is involved with regular servicing of a Planar 3?
As far as the RP3, once you do the TTPSU + subplatter upgrades, you're essentially at the cost of a RP6. As far as the white belt "upgrade", I did it on my RP6. Couldn't hear a bit of difference from the original belt. Granted, the white belt seems more durable.
Posted on: 25 February 2017 by Mike1960
Hi Joe, servicing usually involves checking the main bearing to the platter. This needs oiling and also eventually wears out. Frequency would depend on use, but I would say every 3-5 years now that streaming is my main source. The drive belts eventually stretch too. I am not sure I could tell when I switched from black to white but as you say it does seem more durable and the black belt was routinely changed at service time too.
As to cost, I paid ₤188-00 in 1987 (not 1985 as I wrote before) for my Planar 3. The motor upgrade and TT PSU were approx A$650-00 so significantly cheaper than upgrading to a RP6 (A$1725-00 here with no cartridge), and the OP has a 18 yr old RP3 so is worth considering if the arm is in good condition.
As an aside Rega's support is excellent too. One of the hinges on my turntable lid eventually wore out and broke. Rega replaced the lid with a brand new one. I just paid local postage rates only.
A good indicator of the success of the upgrade is that I almost exclusively played my ND5XS before, whereas now I would say that I use the Rega again for 20-30% of my listening.
Mike
Posted on: 26 February 2017 by Huge
No, that would not have given the ideal balance for my system.
I need to go for a system that presents detail at low to mid listening levels, and the 272 + TXPS / 250DR is better at that than the SN2.
I also didn't know whether I'm keeping my speakers, and one of the options is ATC, probably the 19s. These really benefit from a 250 or higher poweramp; the SN2, good as it is, won't cope quite so well.
Also if you have speakers that are really easy to drive (as are my present ones) then in many ways the SN2 is only a relatively small step up from the XS + a DR preamp power supply, so the SN2 could only ever have been a stepping stone for me. Once I decided to upgrade from the XS 2, the minimum endpoint for me based on an NDX would have been NDX + TXPS / 282 + TCap / 250DR and that's quite a bit more expensive than 272 + TXPS / 250DR and a lot less convenient, but probably also a somewhat better system.
When the 300(DR) (a s/h upgraded 300) came up for only a little more than a new 250DR, my decision was confirmed.
Posted on: 26 February 2017 by Holmes
Just the kind of feedback I'm after and I do have an upgrade in mind but after the Naim amp and streamer are in place...
It is an 18 year old Planar 3 and I had it serviced locally about 2.5 years ago with a new black belt, oiled bearing and carbon cartridge, those motor and power supply upgrades are both affordable, but I suspect that when it gets to that, I may go with the next model up the line at the time.
However I'm pretty sure that the amp and speakers aren't getting out what the RP3 has to offer at the moment. Ripping vinyl to FLAC via the tape out to an 8 year old Macbook pro using Audacity, seems to reveal more when heard on my Fiio X1 and AKG Q701's than I get out of the speakers, although strapping headphones on is bound to be different I guess.
Posted on: 26 February 2017 by Emre
i am using 272/555PSDR/Sopra 2
i am not blaming stageline ( maybe it is my turntable maybe it is the power supply on stageline ) but the sound is not better than digital end of 272.. so i keep asking why did i spend all that money on a turntable...
you need a PS for stageline, natural partner will be a hicap and makes stageline an almost 2000£ phono stage...
you can do much better with that money.... or just get rega aria with your rega....
So you're using RP3 and Planar 3 interchangeably
Apologies joerand for 18 years I've been referring to the Rega Planar 3 as my RP3 what am I missing? :-)
Hey Bob The Builder, now there's a thought and it that has been niggling, with thinking the amp should be the first move, but I want the streaming to explore more music (and perhaps decide what records to buy!) and that's why I started questioning the amp choice / other amp options, which quickly lead to the >NAP200...
I guess I won't really know what my preferred source is until I get a streamer running. I still plan on buying vinyl and have 400+ albums I will keep going back to, so I guess I don't want to take the deck upgrades so far that the quality of my well loved records starts to bother me, so there will be a limit to my system not far beyond upgrades to the current deck rather than moving up the deck and cartridge line too much further. There's so much more to get out of what I have before I do that.
I like sound of getting more low end detail that people speak about with the NAC N 272 and since I'm a bit of a bass head, with a love of Jazz bass lines, roots, dub, afrobeat, soul, funk and electronic break beats etc. I must have a listen...
Bob, yes the low bass frequencies from a good TT are inherently "beautiful, round and resonant" due to the mechanical resonances in the system and the compression/expansion in the RIAA curve, sadly though, it's less accurate than digital, and can sound "beautiful, round and resonant" even when it shouldn't.
If you like that sound, then that's to what you should listen, but please do be aware that, to some degree it's actually a colouration, albeit a pleasant one.
Posted on: 26 February 2017 by Mike1960
"Holmes posted:
Quoting product line from Wikipedia History. The record player has been through four principal guises: Planar 3 (1977–2000) (2016-), P3 (2000–2007), P3-24 (2007–2012) and RP3 (2012-2016).
Hence the confusion, but RP3 is obviously easier to say and write, even if technically incorrect.
Mike
