ndac firmware update - need help
Posted by: PTCM on 27 February 2017
I am trying to update the firmware for my ndac.  I have no idea what version it is.  I followed the manual instruction by holding the dock button and turn it on. It flashes "4", "3", "3"".
what does that mean and am I supposed to install the update files version 4.11.8 or (compatible with flac)  one only or both ? many thanks.
https://www.naimaudio.com/updates
Posted on: 27 February 2017 by PTCM
I connected ndac to a iOS device and found out the firmware version is 3.4.6.
am I supposed to install the update files version 4.11.8 first then the compatible with flac one shown on the link below  ? many thanks.
Posted on: 27 February 2017 by jon h
3.4.6 does not align with your reported light flashes
have you read the pdf file?
Posted on: 27 February 2017 by Dave***t
Just a general note that you can contact Naim support for stuff like this, as detailed here - https://forums.naimaudio.com/topic/naim-support
That said, I imagine some members will be along to help soon.
Hi Jon, I did read the pdf file, but I do not fully understand the conversion table.  The iOS firmware states 3.4.6., which I believe is correct.
should I install the update files version 4.11.8 first then the one named compatible with flac ? or  ?  thanks
look at the dates - the first is december 2015 and the second is may 2010. The first is all you need
(Yes, the date should be clearer)
version 4.11.8 - done.  Thanks a lot Jon.
