Chord Dave vs. DAC-V1
Posted by: thijazi on 03 March 2017
My dealer lent me a new Chord Dave to demo at home for a few days, I set up my system by using two PCs, one is connected to the DAC-V1 (USB) and the second PC is connected to the Chord Dave (USB), both the DAC-V1 and the Chord Dave are then connected to my NAC, I setup a linked zone in Roon grouping the Naim and Chord output so that whenever I playback a track I can instantly switch between both DACs as sources by a mere remote control button click, this gave a good way to compare both DACs "side-by-side" while any given track was playing.
First impressions are that the Dave definitely has a wider, more rounded sound, the soundstage is really big with the Dave, there seems to be extra body to the music, the DAC-V1 holds it's own ground pretty good, however compared to the Dave I noticed that the DAC-V1 sounds a bit "contained", boxed-in, with a narrower sound-stage.
What I found interesting is that the Dave is always louder than the DAC-V1 (I set both to use the NAC volume control bypassing the DAC's own volume control)..
Will test my DSD playback tomorrow, curious to see how the DAC-V1 will hold then given that the Chord seems to be far more versatile with DSD.
It will be interesting to see your findings. When I compared DAC-V1 DSD playback (and Hugo) to my Sony ES players I found the Sony players to be better than both in soundstaging. Hugo DSD was better than DAC-V1 in that regard too, so I suspect DSD playback is not its strength.
I will try it again with my current setup using the microRendu which so far (PCM) gives an amazing soundstage with the DAC-V1!
When comparing music 'enjoy_ability' , play each one for an extended period, i.e. without flicking back and forth within a track for instance, nor fixated on anything in particular (except the music of course)! Very interested in your findings.
Dave in DAC mode has a high output so is always going to sound louder. I use mine in Preamp mode and set the output at -12/13db. That produces the same volume as my Cd555 and NAT01. Sounds better too.
Are you saying that Dave sounds better than CD555?
And a Dave to V1 comparison - I would hope the Dave sounds better - it is only about 4 or 5 times the cost!
A fairer comparison (price wise apples to apples) might be Hugo (or upcoming Hugo2) to V1
I did an extensive one week session comparing a Hugo to the DAC-V1 and at least for me, the DAC-V1 stayed in the system and the Hugo went back to the dealer, there was nothing I found in the Hugo that I didn't get with the DAC-V1, the current setup is different though, the DAVE is sounding better specially in DSD playback... Will try to lower its volume for a fairer comparison to the DAC-V1.
I wish Naim would release a roadmap of their next direction in DAC-LAND... would so much rather stick with a better Naim DAC (and a USB one while we are at it please :-))
I got to hear the Dave a couple of weeks ago,for less than an hour though,it was quite impressive to me,a more fair fight,price wise would be the ndac with 555dr versus Dave I would think.
All Chord DAC's that I remember have 3V output.
It has no analog volume control, all in digital domain, so it is quite ok to lower the volume on Dave to match the DAC V1.
The Dave volume control is very complex and advanced, as it involves also changing the settings in the DAC noise shaper also, so way more sophisticated than what is done in software in a laptop.
The noise shaping part of DAC is quite huge, and the code for it wouldn't fit on the large FPGA in the Hugo.
I think this happens are -7DB on the Dave where it matches the fixed output of a DAC V1.
Not sure which interconnect you are using for Dave into your 552, but with all Non Naim sources, I prefer a RCA to DIN connection. I can easily hear the difference, as the musical experience is more involving and energetic with a DIN connection to the preamp
Depends on your budget, but worth asking Dubai Audio what your options are for the interconnect if you are going ahead with the Dave.
I also found a good quality USB cable will make a difference with DAVE, the Vertere DFI is a good example of such a cable.
as to why different USB cables sound different, one can always google Gordon Rankin why do USB cables sound different.
Gordon Rankin pioneered USB audio with Asynchronous USB.
If you are using J river, then it would best to select the Chord Asio driver which according to Rob Watts, ensures bit perfect delivery to the Dave DAC.
Brilliant,
Please tell more about your good experience on uRendu and V1. Which power supply you have in uRendu, did you do something special to connet it and did you change anything else than just added uRendu? Any special recommendations to connect uRendu?
I have had V1 and recently also Hugo with laptop (Tidal+JRiver21). I consider V1 more dynamic and having more weight in bass. For me Hugo is more clean and lean. I have 282+SC2+300DR.
Thanks, Tuomo
Wait for a hugo2 before Dave, it will be Dave sound 1/3 price and analogmusic will burn his Dave as a Protest!
ha ha no I won't. Hugo 2 doesn't have the capability of Dave.
Tuomo posted:Brilliant,
Thanks, Tuomo
Hi Tuomo,
I understand what you say about the V1 vs Hugo. As for the mR please have a read of the last two pages of this thread and I will follow up with a summary soon.
https://forums.naimaudio.com/to...-of-streaming?page=7
Regards.
B.
A slight deviation, but over the last couple of weeks, I had decided to put aside my Hugo and use my NDX DAC natively via a hiline into my 252DR. The sound was different, a bit thicker and a bit less specific than the Hugo...but I let myself get used to it... and I did get used to the new presentation... What was interesting after severeal days I felt the music was from the NDX was somewhat lacking in involvement.. I couldn't hear into the music just to it... I started to loose interest in the music.. albums that I really enjoy were simply not engaging me...
Yesterday I re applied my Hugo.. and yes initially there was a noticeable presentation change, but despite that..I found I was being pulled into my music again and it was engaging... it held my interest ... I wanted to listen to those albums again
I found this little excursion interesting and to me shows there is perhaps more going on in audio replay with our sub conscious than we might be aware of... and this has become my test for DACs. I will be checking for this affect when I audition the Nova, and to some limited extent this also insightful replay occurs with my CDX2
Simon,they call it evolution,we adapt to the environment around us,after you live in a hot or cold climate for some time,it becomes"normal" to you.I believe our ears work the same way,at first upgrades seem very obvious,then after we live with them for some time,that is the "new normal",and many of us go looking for more,which brings on the next upgrade.
Exactly, you need to ignore the obvious sound presentation differences, as essentially they are in my experience superficial and our brain adjusts... it's what is going on deeper in the audio replay... and with digital replay and audio reconstruction that's a lot that seems to go on that we can't immediately recognise in the sound we hear.. but does affect our engagement.. and the extent our brains have to 'decode' the audio into higher level functions like music..
Thanks for posting that Simon, that is exactly what I found when I got the Hugo.
I think many people compare Hugo to another source, and can't find much difference initially (although it was obvious to me the moment I switched on the Hugo and played the first song)
The issue really is in this area. 44,100 samples per second. Some companies think this is enough, and the brain doesn't need to hear the missing information between 44,100 samples per second.
However Chord do think it is audible and go to extreme lengths with massive FPGA processing, to recreate the missing samples (mathematically), and certainly this is audible to me.
this is some technical information from their first DAC 64
"The WTA filter algorithm has taken twenty years of research to develop. It solves the question as to why higher sampling rates sound better. It is well known that 96 kHz (DVD Audio) recordings sound better than 44.1 kHz (CD) recordings. Most people believe that this is due to the presence of ultrasonic information being audible even though the best human hearing is limited to 20kHz. What is not well known is that 768 kHz recordings sound better than 384 kHz and that the sound quality limit for sampling lies in the MHz region. 768 kHz recordings cannot sound better because of information above 200 kHz being important – simply because musical instruments, microphones, amplifiers and loudspeakers do not work at these frequencies nor can we hear them. So if it is not the extra bandwidth that is important, why do higher sampling rates sound better?
The answer is not being able to hear inaudible supersonic information, but the ability to hear the timing of transients more clearly. It has long been known that the human ear and brain can detect differences in the phase of sound between the ears to the order of microseconds. This timing difference between the ears is used for localising high frequency sound. Since transients can be detected down to microseconds, the recording system needs to be able to resolve timing of one microsecond. A sampling rate of 1 MHz is needed to achieve this!
However, 44.1 kHz sampling can be capable of accurately resolving transients by the use of digital filtering. Digital filtering can go some way towards improving resolution without the need for higher sampling rates. However in order to do this the filters need to have infinite long tap lengths. Currently all reconstruction filters have relatively short tap lengths – the largest commercial device is only about 256 taps. It is due to this short tap length and the filter algorithm employed that generates the transient timing errors. These errors turned out to be very audible. Going from 256 taps to 1024 taps gave a massive improvement in sound quality – much smoother, more focused sound quality, with an incredibly deep and precise sound stage."
No quarter posted:Simon,they call it evolution,we adapt to the environment around us,after you live in a hot or cold climate for some time,it becomes"normal" to you.I believe our ears work the same way,at first upgrades seem very obvious,then after we live with them for some time,that is the "new normal",and many of us go looking for more,which brings on the next upgrade.
More like acclimatisation rather than evolution. Acclimatisation is about getting used to something, which is what's happening here, whereas evolution is about gradual change over time. Whatever, I'm sure you are right. Some things are hard to explain. It's not about bass, treble, detail, separation or whatever, but about whether music sounds more real, more engaging, flows better, or is simply nicer. It's exactly what I found when I changed my network switch.
Out of interest, please would someone explain (simply) what these 'taps' are and why they are important. The quoted article mentioned tap length, then went on to talk about tap number, which seems odd.
in a very simplistic way, I think (and maybe Simon Can elaborate more) taps means how many additional samples the FGPA processing is re-creating.
Hugo re-creates 26,000 additional samples (between the 44,100 samples)
Dave does 168,000 samples
Dave also has much superior pulse array DAC compared to Hugo and Hugo 2.
Nigel... regarding 'taps'.. one of my pet subjects. ![]()
A sample stream is a continuous stream of discrete samples. If one needs to modify or filter that stream of samples, one has to process that stream, or multiply that stream by another sampled waveform, i.e. The filter function,.. over a period of time.. like a moving window over the original sample stream where the result at a point in time is also derived by what is before it and ahead of it.. Now for the infinitely best response, the filter window needs to be infinitely long.. otherwise digital distortions or inaccuracies are introduced. Clearly one can't have an infinitely long filter function, so it is reduced in size to be practical. Now with this reduced size the more inaccuracies are introduced .. now mathematicians have developed special windowing functions to reduce these inaccuracies, but despite this, having a larger window size and filter function waveform tends to give better results.
Now the word 'tap' refers to a discrete sample of this filter function or filter waveform. So the more taps you have the more samples in your filter function or filter waveform you have. This means when the window of this filter function is passed over the continuous bit stream, the modified result will be more accurate..
The above is simplistic, and there other ways of filtering such as recursive filters, but genereally this approach is often preferred, where the processing power can be provided with undue side effects such as noise.
The reason we need to filter is another topic... but simplistically apart from low pass filtering, you need to force the DAC to treat each sample as an infinitely short spike of a value rather than a step.. this requires multiplying (convolving) the discrete sample stream by a sinc filter function waveform.. often what is termed the reconstruction filter function.
So in short, the more taps, the more accurate the filter waveform, and the more accurate with less artefacts the reconstructed analogue signal.
In the limit the more processing you do the more side effects through noise you create, which acts against the increased resolution. That is why until the relatively recent arrival of very low power FPGAs, there was little point in having larger filters as in doing so produced too much noise / complexity.
Just spent the best part of the day listening to the Dave in DSD Plus mode and the music is stunning. This ability to "Reconfigure" the Dave for either DSD or PCM optimized playback is one of the main reasons I wanted to test it... The improvement from the DAC-V1 in FLAC file playback is notable but in my humble view hardly justifies the price delta. In DSD though, it is a totally different game, the Dave is totally at home with DSD playback..
Never tested an nDAC with a 555DR although I would love to stick to Naim for most of the gear... I am not sure how that would work given that I am nowadays rely totally on Roon. If I move to nDAC/555DR then I would have to rely on the Naim app for music playback (or am I not understanding this correctly??)...
[@mention:69004037368204356] I did borrow the Dave from Dubai Audio, (you are sharp :-)).... Using an Audioquest Big Sur RCA interconnects so not too bad there.... Have older Chord VEE3 DIN-2-RCA interconnects however their pin configuration does not fit the NAC552 (I used them with the NAC202 in the good old days)... Will order new ones if I end up keeping the Dave...
I am also researching the PS Audio DirectStream and the totalDAC options....
Simon, thank you for taking the time to write such a comprehensive and helpful reply. One of the main problems I have from my acquired brain injury is that I have real problems processing complex information - it sounds very much as though I need more taps!! I'll re-read your reply a few more times and hopefully will then grasp it all.
Tareq not sure but the Chord DIn to RCA would fit the 552 also, maybe the 552 needs to be reconfigured to allow RCA inputs rather than DIN for that input.
As for price delta, between DAC V1 and Dave, it is exactly as Simon explained, Dave does something completely different, after couple of days of owning Hugo and listening to it then clicked on me - this has all the excitement and dynamics of live music. Bingo, Rob Watts has hit the bulls eye !
I can hear this with any amplifier I have connected Hugo/ Dave to by the way, there is a "stressless", free flowing, just like live concerts. You can hear more clearly how the musicians are performing and the emotions, with other DACs, they play a little mechanically. It isn't immediately obvious it does take careful listening, Dave has a lot more refinement, much better small signal resolution, and you should hear increased 3d soundstage with suitable recordings that have it to begin with.
And once I latched on that quality (free flowing, stressless, live concert fee, or as what hi-fi says : fluidity of Vinyl) of Chord Hugo, Mojo and Dave, it become intoxicating, and I cannot go back now from that.
I wouldn't bother with the alternatives you mentioned, others who did the comparison on head-fi reported that Dave beats both of them.
Hi Nigel, thanks, sometimes it's difficult without diagrams and I find many so called web wikis are too simplistic which lead to more confusion. This has some good diagrams. More formally you see the term 'coefficient' instead of the marketeers preference of the word 'tap'.. but they are the same.
http://lavryengineering.com/pd...ding-fir-filters.pdf
Yes we are talking with filter windows and taps FIR (finite impulse response filters) and sin(x)/x is the sinc function I referred to...
Ali, glad you still enjoying your DAVE ![]()
well to see the difference again, I plugged in my trusty Mojo into my 282/250 Dr rig, along with my Dave.
one can hear they came from the same company, but the Dave is just more musical, refined, clear, and has much better microdynamics and macrodynamics both. Listening to the same song on Mojo, compared to Dave, well, just not the same...
It is obvious from the first guitar note : much more musicality, emotion and clarity from the Dave (tidal Billy Idol - BFI Live album - track "eyes without a face")
Both fed from the same laptop. So no software differences....
