tag albums n serve
Posted by: French Rooster on 03 March 2017
hello,
can someone help me and tell me how to put photos on albums downloaded on the naim unitserve. i have downloaded the desktop client but no album appear. ?  have i miss a step?   thanks in advance
Posted on: 03 March 2017 by Adam Zielinski
Downloaded albums cannot be edited, only the ones ripped by a UnitiServe can.
To edit files, use a \n editing software like Metadatics.
Posted on: 03 March 2017 by French Rooster
thanks adam for your response. But i have already succeeded to change the photos on downloaded albums ( qobuz) that are now on my unitserve. But i can't remember how i have done that. I remember the desktop client, and that all my albums appeared on my pc and i have changed the covers. I have found the photos covers on google and memorized them on my pc. On desktop client i have put them on certain albums. But now my albums don't appear, i don't know why.   I am waiting naim support, i asked them.  But it is possible, i have managed it in the past....  thanks again
Posted on: 04 March 2017 by Richard Morris
You can add or replace an album cover - which must be called folder.jpg -  in a downloaded file without using Metadatics. Just mount the Downloads volume and drag the folder.jpg into the relevant folder.
Posted on: 04 March 2017 by Adam Zielinski
The OP specifically asked about the nServe app. Editing downloaded albums via the nServe app is not possible.
Working outside of the app - editing can be done in various ways.
Posted on: 04 March 2017 by French Rooster
yes inside the n serve app it is not possible. but with pc, using desktop client, it is possible. but i forgot the steps to do it...
Posted on: 05 March 2017 by DrPo
on a PC you can use mp3tag (free s/w) but also the metadata utility of dBpoweramp if you have it (ID-Tag) or foobar (also free s/w)
Posted on: 05 March 2017 by French Rooster
the problem is that i can't see my unitserve 's rips and downloads on my pc , when i open desktop client. The unitserve, called nsrr941 is choosed but i can't see the files or albums.  ?
Posted on: 05 March 2017 by Adam Zielinski
Are the folders properly set up as STORE and SHARE respectively?
Have you activated them and do they have 'guest access with all read /write' priveladges enabled on the folders?
