Naim 322 cards issue
Posted by: jarvicseven on 09 March 2017
Hi again,
I purchased some Naim 322 cards the other day and fitted them, however, one channel is much, much lower than the other side, I have to have the balance knob cranked 95% over to one side to get the balance correct, also meaning I have to run the volume far higher to listen to anything, I never had this issue with the previous 323 cards I had fitted,
Could this be an issue with one of the cards?
Is there anything I can do to correct this issue?
Thanks for any help and advice proffered.
Posted on: 09 March 2017 by Richard Dane
Are they fitted correctly?  What is the pre-amp?  Later units need links on the main board cutting.  If you've already had phono boards working OK then that shouldn't be an issue.
Beyond that,  how old are they - what issue? Note that pretty much all of them will be over 10 years old now, so servicing is recommended.  The oldest will be nearing 40 years old!
Posted on: 09 March 2017 by ianrobertm
Statement of the Obvious - contact the person you bought them from. Return & Refund....?
Posted on: 09 March 2017 by jarvicseven
Fitted exactly as the old 323 boards were fitted,
NAC62 pre amp
Yes, indeed I had the 323 boards functioning perfectly before,
From studying other 322 board images on the net they are 322/1 boards
Thanks for the advice, I have contacted the seller in regards to returning them,
Thanks as always for the advice,
OK, if they're NA322/1 boards then they are almost an ancient artefact.  If they have not been serviced in the last 10 years they are desperately in need by now.
Posted on: 10 March 2017 by ianrobertm
[@mention:61543321023657407] - Good decision, to look at return. Hope the Seller is reasonable, or you have some protection, via your means of purchase. Surely there are some better, newer 322 'N' boards out there....? (No... you cannot have mine......!!!! My 72 needs them.)
Posted on: 10 March 2017 by Richard Dane
It's worth bearing mind that improvements to the circuit were made with each re-issue.  I would be looking for at least NA322/2 but preferably NA322/3 or best of all NA322/4.  They're all old now so be aware that a service is probably a good idea.
Just found V4 inside my later version NAC72.
