Audirvana volume control
Posted by: DanT87 on 09 March 2017
Everyone,
i am using audirvana 3 plus with DAC V1
should I have volume control on the computer program itself? I've heard it disappears? Or not?
Posted on: 09 March 2017 by dayjay
You should have an option to either have volume in software, volume on the device or both in preferences.  I don't use the volume in Audirvana at all but it is still there
Posted on: 09 March 2017 by banzai
Some people are saying that using Audirvana's volume can impact the sound quality.
Posted on: 09 March 2017 by DanT87
Yeh I've got
volume control type
DAC only ✅
DAC if available else software
software only
selected DAC only is this correct?
AND also direct mode doesn't work?!?
If ou have it set at DAC only you won't be able to control volume from within Audirvana, to do that you would need to select a software option.  I don't use volume control for SQ reasons and because it doesn't work on DSD files anyway whcih is a pain
Yes so whatever it displays is irrelevant?
what do I need to do to get direct mods working?
