Sold my orginal uniti - bought a Mu-so Qb
Posted by: Mrs Wogan's lemon drizzle cake on 12 March 2017
Hi all. So i sold my old original uniti thinking that the streaming hardware (ie its 20p CPU) was a bit long in the tooth and may not be able to keep up with advances in streaming audio. I didnt fancy shelling out for an upgrade card and TBH that system was a bit overkill in my kitchen as the acoustics in the room are rubbish anyway - tiled floor and lots of glass. Sold it and also my kef LS50's.
So plan was to replace it with a bog standard amp which i could plug my macbook pro into. How bad can a "cheap" amp be? We.... I ended up with a Cambridge audio jobby for 150 quid, however i soon realised that the amp was terrible quality (sound only comes out of one speaker at low volume, which is a "feature " apparently).
It also made an annoying humming sound, even without anything plugged in. Anyway back to Richer sounds that went.
Anyway long story short I replaced it with another Naim - a Mu-So QB which me and the other half are really happy with. Sounds just as good as the uniti in my kitchen tbh.
The only problem I have is getting "random" play to work on my UpNp collection - i'm aware that playlists are limited to 500 tracks, is there any way around this?
I used to get around this limit on the uniti by hitting "play on all tracks" and selecting random on my uniti's remote, but obviously this isn't possible with the QB - is there any way around this? I do hope so as this 500 track limit sucks.
Cheers!
