brave new digital world
Posted by: kota on 13 March 2017
Sorry for the lame question but I'm old school. What should I get in order to rip all my cd collection and connect it to my NAC72 instead of using my cd3.5 ? On the cheap side please and using my laptop/broadband internet connection without compromising sound quality as it is right now ?
Pedro
Posted on: 13 March 2017 by Bert Schurink
So I would suggest you rip with your laptop and the software dbpoweramp or eac. Then I would suggest you put your files on a nas like Qnap or Synology. Store the files in Flac and play them in Wav by using mimeserver or asset...
Posted on: 13 March 2017 by nickpeacock
Software: as Bert says, you need good software to rip (copy) the CDs. Make sure you rip in a lossless format. I use dbpoweramp. You also need decent software to control playing the music - itunes will work but there are better. If as Bert (rightly) recommends you store your music on a network drive/NAS then asset or minimserver are favoured by the forum.
Hardware: you need a decent DAC between your laptop and pre-amp. This could be a stand-alone (Naim has Dac-V1 or nDac; Chord make various Dacs - is a Mojo too much? How about an Audioquest Dragonfly to get you going?) or included in a digital player (Naim ND5 XS and up). Cheap' has a variety of possible meanings but you could start with the dragonfly and work upwards from there. Not sure about a cable from dragonfly to Nac72 - others here may be able to help.
Search the forum with the above in mind and you'll start to get some ideas.
Posted on: 14 March 2017 by cat345
The cheapest way would be the Audioquest dragonfly black with a 1,2v. output that would not overload the NAC72 and a subscription to Tidal HiFi. No CD to rip and nothing else to buy.
Posted on: 14 March 2017 by kota
Thanks for that guys.
I'll try some of your suggestions and report back.
Posted on: 16 March 2017 by NickSeattle
I started with iTunes and an analog patch cable from a laptop.  As long as you rip to AIFF, songs will be as good as they can get.  You can move them to a NAS later, if you want.
Other rippers like XLD and dbPoweramp are better if you want album art embedded in the songs -- recommended.
After that, you can tinker with hardware upgrades infinitely -- the Dragonfly being an excellent first one.
Nick
