Do Olive 140s have re-wirable transformers?
Posted by: ngarritson on 18 March 2017
I want to replace the 100 that is currently backing a V-1/72/hicap front end with an olive 140. They're hard to find in the States but there seem to be plenty of them floating around on U.K. auction sites. Do olive 140s have re-wirable transformers? The implication seems to be that if the transformer is re-wirable, the voltage conversion is significantly cheaper than if the entire transformer needs to be replaced.
