Add a specific internet radio station as one of your presets
Posted by: Zackwater on 18 March 2017
If I'm listening to a particular internet radio station how do I add it to the presets on the naim app?   I'm using an iPad Pro.  Thanks
Posted on: 18 March 2017 by Dave***t
Press the star on the now playing screen.
Posted on: 18 March 2017 by Zackwater
Thanks, I'll do it when I get home.
Also, when you've got a few station presets saved, don't forget you can scroll to the bottom of the list and tap edit presets, then drag the stations up and down to change the order in which they appear.
Can help with showing the stations you listen to most if your list gets a bit unwieldy.
