Sky Q, Internal Powerline adapters and my Naim
Posted by: Simon-in-Suffolk on 19 March 2017
To share an advisory tale on Sky Q. I had ordered and have just had installed a Sky Q box and a Sky Q mini box - It was initially quite an ordeal with some challenging Sky customer services experiences - but moving on. I had the Sky Q and Sky Q minibox setup with ethernet.. all was ok but I noted my Naim was sounding a little 'dry'.. It was bugging me.
Separately I noted that the Sky Q boxes were creating their own Wifi SSIDs even though I was using wired ethernet... I had to get sort this... a quick peruse on google and I found how to get into the 'Installers menu' - Home- Settings - 0-0-1 - select .. and I proceeded to turn off the wifi radios - but also in that setting area I found the internal Powerline adapters were activated on the Sky boxes - Jeez - that was a sneaky thing to find - so I disabled them on both the Sky Q and Mini Box and yes my Naim returned to sounding itself again...
Yes it could all be psychological, but I suspect not - at least Powerline technology and unnecessary wifi SSIDs are now disabled and am simply using efficient ethernet connectivity with perfect connected Hidef .
The worry thing is that unless you go into the Installers menu there is no way of knowing that this horrible Powerline technology is activated...
