135 connection to supercap
Posted by: Sounsfaber on 20 March 2017
Hi,I'm having a bit of trouble trying to get my channels correct.
My 135's are from 88 as far as I know they are the last CB's (dressed in olive now)
Standing from the back, I have the bottom 135 as the right hand channel the red cord into the right side XLR plug (looking from the back) and that goes up to SC far right din, on second from the bottom level of my rack is the other 135, that has the green cord coming from the left side XLR which heads up to the din just to the left of the other channel (right) of the SC then off to the 52.
The problem is when I turn the balance on the 52 to the right (looking from the front) the volume goes to the left and the opposite when rotated to left.
the only way I can get the balance to work correctly is to change the speaker cables over which really doesn't help my OCD.
i have new mono XLR cable's and the 52/SC just come back from a service. It was doing this before the service but It didn't bother me at the time as I'm not so smart and should of got Chris to look at it my bad. Now it bothers the hell out of me after the service. The boxes are 2000 models and are my dream kit.
the Nac52 had a balance pot replaced a while back (not by our local agent) do you think they may of cocked that up, or am I just a numnut???
I do have awesome support over here I just don't want to bother them when I can do a bit of trouble shooting first
where am I going wrong please help.
thanks
