in the naim app, you choose first the core. Then with the settings, you choose importing music. Normally your nas must appear on the app and you click on importing. I have done that to import albums and files from the unitserve to the core, so i imagine you can do the same from nas to core.
Posted on: 23 March 2017 by Octa_dyn
Thanks I'll give that a try
Posted on: 23 March 2017 by David O
Or if both are on your network, find the files on your NAS and do a copy and paste into the downloads file on the Core....the Core then does the rest
