NDX, HDX, and Core as digital sources
Posted by: Stefan Vogt on 28 March 2017
I'm planning some comparisons of digital sources next week, and wonder what (subtle) differences I should expect - any hints would be most appreciated! So far, I'm expecting similar results for all setups below, though the top (NDX) is possible 'best', and using the 272 in UPnP-mode might be the 'worst':
1a. NDX -> Hugo TT (using Coax; the NDX would stream from the Core) -> 272 analog-in
1b. Core -> Hugo TT (using Coax) -> 272 analog-in
2a. HDX -> Hugo TT (using optical) -> 272 analog-in
2b. HDX -> Hugo TT (using Coax) -> 272 analog-in
3. Core ->  272 using UPnP and the 272's internal DAC
Posted on: 28 March 2017 by Mayor West
Can't offer any insight but would be very interested to hear of your results
Posted on: 28 March 2017 by Richard Dane
Stefan, what digital coaxial interconnects are you using between the sources (when connected via coax s/pdif) and Hugo TT?  This may well be critical to the end result.
Posted on: 28 March 2017 by Emre
Melco USB - Hugo2 USB- 272 analog in is what i have in mind......
Posted on: 28 March 2017 by james n
Am i the only one thinking that apart from Option 3, the 272 is a bit of a strange choice ?
Posted on: 28 March 2017 by hungryhalibut
These 'I'm planning X, what will I find?' questions always strike me as odd. Why not just try it and report back? It also raises a question of why bother with a 272 if there is an NDX, HDX or Hugo TT in the picture? Surely using them with a standard preamp would make more sense, unless the objective is to collect as much overlapping equipment as possible.
Posted on: 28 March 2017 by ChrisSU
james n posted:
No. Could have been a typo, the 8 key is next to the 7.
Posted on: 28 March 2017 by Sloop John B
Stefan Vogt posted:
I wouldn't be expecting the differences to be subtle at all.
It strikes me that you'd be looking for a 3-4cm lowering of the noise floor with these options, even more as Richard points out with optimised cables.
There also quite likely to be 50-100 nm frequency difference in the blackest blacks  which should be perfectly audible at a decent volume but are less perceptible at lower volumes.
Musicality is the other major factor here to be aware of, I'd be expecting overall a difference of 17-21bs in the musicality spectrum.
do let us know how you get on
.sjb
Posted on: 28 March 2017 by French Rooster
Stefan Vogt posted:
you have not the 1a option with ndx streaming from the hdx. or i have read wrong ?
I would place the 1a for best sound quality...
Posted on: 28 March 2017 by Stefan Vogt
Thanks, Richard, I'll use the naim DC1 digital interconnect. Between Hugo TT and 272 I use a Chord Signature.
Yes, the 272 can do the streaming/DAC very nicely on its own. It's the only preamp I have, but then I do like the Hugo TT, which led me to the options above...
S.
Posted on: 28 March 2017 by Wm.
Didn't read the post, just came in here to lament how much I miss Core after having it on home demo.  Tidal is a blah-fest since.
