Harmony Elite conflict with System Automation
Posted by: William on 01 April 2017
Just bought a Harmony Elite. When I switch the TV on, Harmony automatically selects the Tuner input on my Nait XS 2 for sound output to speakers. So far so good. But if I activate system automation on my NDX (for volume control via the app), the XS 2 input switches back to CD (streamer input) on its own. I didn't find the manual very illuminating on how SysAutom works so please can anybody help?
Posted on: 01 April 2017 by Huge
Take a digital (S/Pdif) feed from the television to the NDX, get the Harmony to select that input into the NDX and then it'll all work fine.
Posted on: 01 April 2017 by William
Thanks for your help Huge, sounds like an easy fix. Wish I'd studied electronics!  I didn't mention the sound is actually coming from a bluray hd recorder via scart/cinch adapter. It's a Panasonic DMR-BCT720 and it has a TosLink digital out, so what exactly do I need in terms of adapter/cable to get the TosLink talking to the S/Pdif?
TosLink is S/Pdif!
You need a TosLink to TosLink optical fibre (aka an optical 'cable').  One end goes into the source (try it into the TV rather than the BlueRay as you may get TV sound through the HiFi as well (much clearer the the inbuilt speakers), the other end goes into the NDX.  Select the NDX's optical in and there you go.  If you don't get sound make sure the Blueray and TV are set to output 2 chanel stereo (to the HDMI for the BlueRay and to the optical out for the TV).
If it still doesn't work, take the optical feed direct from the BlueRay.
Posted on: 01 April 2017 by Mike-B
I have optical from TV to NDX & thats the 'Digital-3' input on the app.  Its very easy to set up.     Connecting to TV means you get the sound you see on TV - freeview, BlueRay, Sky  -    Select 2 channel & PCM if you have it in TV options.     The NDX-Nait System Automation needs to select NDX & Digi-3 to play.
"TosLink is S/Pdif!" Doh! :-)
Ok, well since I've already got an Apple TV going into the S/Pdif on the NDX, I suppose there's a Y-splitter thingy I can use at the TV/Apple TV end?
Never mind my last post, I got it now and it works great via the TV and Digital 3. My setup dates back to the day when my old Apple TV wouldn't send the sound over hdmi. Thanks again Mike-B and Huge for your help.
