UnitiServe Artwork solution. NOW!!!!!
Posted by: antmast on 03 April 2017
I need an artwork solution. I am now using the unitiserve as a server to the SIMAUDIO MOON DAC and I am inheriting all this beautiful music with missing cover art. The more files I add the more artwork disappears, even the old artwork is beginning to disappear. For a while I left the Unitiserve and used DBPowerAmp Asset, and the artwork restored itself. I even converted all my Naim ripped files to flac, and their covers where copied down and renamed folder.jpg. However now I found that the Unitiserve server has tighter bass and wider staging than the DBPowerAmp Asset. The UnitiServe serves it better. So I am back to the old artwork problem. Would it be worth while to use the Naim Desktop Client to purge the image database. Would this rebuild the database using the folder.jpgs reliably? I thought I'd should ask before I tried.
