Uniti Firmware Update - does it need to be incremental?
Posted by: Dinarius on 09 April 2017
I am running Version 3.9 at the moment.
I want to update to 4.4
Must I update to 4.3 first and then 4.4?
Or can I go directly to 4.4 and also have the improvements that came with 4.3?
Many thanks.
Denis
Posted on: 09 April 2017 by Mike-B
You can go straight to 4.4
Posted on: 09 April 2017 by Dinarius
Mike,
Many thanks for the prompt reply.
Denis
Posted on: 09 April 2017 by ChrisSU
I can confirm that Mike is correct, you can just go straight to the latest version. It can seem a bit daunting if you've never done one of these updates before, though. Make sure you read the instructions and follow them to the letter and you should  be fine.
Also bear in mind that an older Uniti with the 24/96 board will not support all of the new functions. You may be able to upgrade to the 24/192 board, at a cost, if you decide it's worth it.
Thanks.
I presume that if I've got the older board, it will still update to 4.4; I just wi t have all the functions.
Correct?
Thanks.
D.
Yes, you can still do the update.
