Anyone use WorldWire MATRIX 2 POWER BLOCK on the system ?
Posted by: marcobb on 16 April 2017
Hi Folks,
Any comment on this power bar ?
marcobb
Posted on: 16 April 2017 by nigelb
Yes.
It is an improvement over the Grahams Hydra it replaced.
Posted on: 16 April 2017 by ryder.
I use one in my system. Not much bling and fancy stuff, and it's effective.
Posted on: 16 April 2017 by ken c
you meant 'wireworld'?
yes, i use one in my 2nd system and also another one to power my network components. i more or less take it for granted really...
enjoy...
ken
Posted on: 16 April 2017 by pz
Yes I do. It distributes power to my boxes as expected.
Posted on: 17 April 2017 by AI17
I use one and it made a positive difference to sound compared to the no name extension block I was using before (removed a hardness from the music). I also compared it to a much more expensive isotek evo product and the wireworld was clearly better in my system.
Posted on: 17 April 2017 by Adam Zielinski
I have two of those - neutral is probably the best word to describe it.
Posted on: 17 April 2017 by marcobb
Thanks everyone comment !!!
Which component are you connect  to the socket 1 to 6 ?
Amp or source first ???
Thanks a lot !!!
Posted on: 17 April 2017 by NFG
marcobb posted:
Thanks a lot !!!
Im no expert here, but I did used to run a small power station 2 * 1.8MW turbines with a diesel for backup
I would connect the items with the largest current drain ie: power amp, nearest to the power cord which I assume is socket 1.
N
marcobb posted:
Thanks a lot !!!
Wireworld Matrix 2 is star-wired, so connection sequence is not important. Each socket has the same priority.
Adam Zielinski posted:
marcobb posted:
Thanks a lot !!!
beat me to it!
Id still probably put the power amp in socket 1, out of habit.
Thank you everyone, I will try it later.
Hi Folks, what power cord are you using on the Wireworld Matrix 2 with your system ?
Posted on: 17 April 2017 by Eoink
I'm picking one up next week to power NDX, HDX, HICAP, NAPSC (those 2 into 82) and 2 * 135, my feeling being that at the price it's worth a punt, if it doesn't deliver it's a quarter of a single Powerline, so I won't feel a huge loss. I'm planning to try it with a Powerline Lite as a feed.
Posted on: 17 April 2017 by David O'Higgins
Eoink, I feed mine with a powerline and I suspect that's best.
Thanks David, I'm going to try with the Lite, but I expect a full fat PL will be needed, but worth a try.
Posted on: 17 April 2017 by elkman70
I feed mine with a Powerline too
Posted on: 17 April 2017 by nickpeacock
Mine is also fed with a Powerline, as are all my Naim boxes.
David O'Higgins posted:
Hi David, just feed the PL to the power bar only, other naim box use the normal one ?
Posted on: 17 April 2017 by nigelb
I used to feed my Matrix 2 with a Powerline but then put the Powerline from the Matrix 2 to my 250DR and fed the Matrix 2 with a Supra LoRad 2.5mm. I believe it was better this way but as with all these things, a marginal improvement at best I would say. Worth experimenting though if you can be bothered.
Posted on: 18 April 2017 by David O'Higgins
marcobb posted:
Powerline into everything. It's best, I'm afraid!
Posted on: 19 April 2017 by marcobb
What cable are you connect from the wall socket to WW matrix 2 ?
Naim Standard or PL ?
Cheers ~~~
Posted on: 19 April 2017 by Adam Zielinski
marcobb posted:
Cheers ~~~
Standard NAIM cable
marcobb posted:
Cheers ~~~
Standard NAIM cable
Thanks, did you try PL before ?
Posted on: 20 April 2017 by marcobb
Hi, is it all the socket star wired ? only 3, not fully star wired ?
Cheers ~~~
Posted on: 27 April 2017 by marcobb
Anyone has comment on this star wire ?
