Where's my bottleneck
Posted by: True Blue on 18 April 2017
As above given my system whats the limiting factor ndx source or pmc gb1i speakers?
Posted on: 18 April 2017 by varyat
The Stageline imo...
Posted on: 18 April 2017 by Bob the Builder
I would also say the stageline there are so many better phono amps around for that money I would get a Rega MC Phono amp, Rega MC Cartridge - Rega arm - Rega Deck - Rega MC Phono amp makes sense.
Posted on: 18 April 2017 by True Blue
Didnt think of the stageline tbh as 90 percent of my listening is now via ndx
Posted on: 18 April 2017 by Pcd
If that's the case try a XPS dr on the NDX major improvement.
Posted on: 18 April 2017 by Christopher_M
NAC252 calls for NDS, I read here.
C.
Posted on: 18 April 2017 by The Strat (Fender)
What do you think could be improved?
Posted on: 18 April 2017 by james n
The GB1i speakers will eventually become a bottle neck (and i say that as a very attached owner) as you move further. Saying that, they are fine speakers that are very capable of showing improvements up front so if they still work for you and work well in your room then i'd look elsewhere.  DR'ing the 250 and Supercap would be worthwhile and as suggested above, take a look at the NDS (orif if floats your boat, a Chord Hugo, fed by the NDX).
Food for thought
Tbh not sure. Am happy with the sound but am not sure the ndx or the speakers are getting the most out of the 252 sc 250 combo.
Supercap being dr'd in august. 250 is only a couple of years old. So dr later.
Posted on: 18 April 2017 by benjy
Rather than ask which component is the weak link,try to describe what you think can be improved upon,maybe by each source or if it is on everything. The general question you are asking is more like asking members to help you spend your money (granted alot are willing to offer up an opinion so - ez when it's not their own money). If you are happy with the sound as it is, don't be so anxious to succumb to upgrade-itis (as most of us have- myself definitely included)
Posted on: 18 April 2017 by Drewy
How much have you got to spend? What's the problem with what you've got?
There is absolutely no problem with what I have. Suppose just looking for reassurance that the 2k speakers are up to the job. Sometimes think that the pmcs are a bit edgy I suppose a bit harsh only very very occasionally. Ndx source at times also seems a bit digital.
Budget reckon around  the 2.2k mark
True Blue posted:
XPS on the NDX.
Posted on: 18 April 2017 by Timo
If you still like the PMC signature, have a listen to the new 25.23. I am very happy with my beautiful oak pair, but I understand the 25 series is somewhat controversial here... And when the new Hugo is out, I would also give it a try. I am not so sure about the NDS -- purely because of speculation that the Uniti platform might spill-over very soon. If you don't like the Hugo, I would then rather wait for the NDS2 -- and first improve the speakers...
Posted on: 18 April 2017 by Simon-in-Suffolk
Definitely the NDX analogue output stage on that setup, try either an NDS or a third party DAC like a Hugo on the output of the NDX (NDX in transport mode)
S
Simon thanks for the response. Very similar systems we have
Posted on: 18 April 2017 by Adam Zielinski
If digital is your main source, than NDX analogue output stage might be holding you back.
Two options:
Option 1: get an external DAC (a 3rd party DAC or Naim's own nDAC + power supply -  555PS is the best choice)
Option 2: get an NDS + 555PSDR.
If you don't mind many boxes an NDX + nDAC + 555PS is a very fine streamer. Up there with NDS + 555PS.
With regard to your analogue side: I actually think that a Rega phono stage (Aria) would be a better match for your Apheta. Aria is optimised for a relatively high gain needed to run Apheta well (gain needs to be somewhere in a range of 63 dB or so).
Posted on: 18 April 2017 by Kevin Richardson
I imagine the NDX is pretty weak in your system. After buying an external DAC, I can't listen to the NDX DAC on my meager SN2 system. The Hugo was great until my battery died. I replaced it with a Berkeley Alpha and found this combo perfect for my ears. Why spend 8,000$ on a power supply when the new improved Hugo2 is only 2,500$?
Posted on: 18 April 2017 by thebigfredc
IMHO your speakers.
Try lots of others and you will be amazed how good your system can sound.
Ray
Posted on: 18 April 2017 by analogmusic
why not try superlumina interconenct cable between NDX and 252?
Posted on: 18 April 2017 by jon h
what sort of music do you listen to?
Posted on: 19 April 2017 by True Blue
Music is very varied from country and prog rock. To rock, pop and heavy metal. Depends on my mood.
Posted on: 19 April 2017 by cdboy
After you do the SuperCap DR, try an XPS DR, then SuperLumina interconnects. You'll hear a box like upgrade at each step. A lot to enjoy along the way.
Posted on: 19 April 2017 by Harry
True Blue posted:
I ran a pair of £1.1k speakers off 552/300 for about a year. They loved it. They never sounded better. In fact they sounded better than a lot of prospective upgrade candidates because they matched so well with the room.
Posted on: 19 April 2017 by Pcd
analogmusic posted:
You really need the XPS on the NDX to reap the full benefits of the S/L interconnect between the NDX and 252.
