Off the deep end
Posted by: MangoMonkey on 20 April 2017
its great when I'm working 60 hours a week. Don't have time to futz around with the stereo.
yestrday - decided the stereo didn't aesthetically appealing on the fraim. Most pics show the naim gear edges all the way to the front and tried to do the same.
30 minutes later - system sounds super bright. Unbearably so. Maybe not bright / certainly noisy.
Hmm / maybe the cable dressing got messed up? Residual mucrophonics?
last night tried to fix the cabling as best as I could. No help.
maybe I've gotten used to the Harbeth sound and kudos too bright?
went to bed early.
this am - system still not recovered. Still too bright sounding.
Pushed the 552 about 1/2 - 1 an inch in towards the back.
system is singing again.
at times like this, I wonder why I bother with Naim. Sell the lot of go back to a nait 5.
who am I kidding. I have no delusions of being able to downsize. Still - 300 to 250 probably worth it - If it takes away some setup stuff. Next step 500?
Posted on: 20 April 2017 by Foot tapper
Hi MM,
Statement. Less need to faff around with placement on the FRAIM shelves.
I'm reliably informed that all 3 Statement cases manage to function without a FRAIM shelf underneath them.
Voilà!!!
Posted on: 20 April 2017 by JRHardee
It might be a bit harder to scoot a 500 back and forth with your thumbs.
Posted on: 20 April 2017 by b_lund
Muso
You have been there before
Not sure I catch your point with these threads of you
Posted on: 20 April 2017 by MangoMonkey
Now - I do wonder - moving the 552 back did have the effect of increasing distance between the 552 and NDS burndies...
Posted on: 20 April 2017 by ryder.
You may consider getting the Nait 5 or any integrated amp for that matter as an alternative amp where you can swap in and out of the system at any time. In other words a backup amp. I wager you will return to the 552/300 in a matter of days or hours, or perhaps develop a higher appreciation for the bigger amp(s) more after having a short stint of listening fun with the smaller amp.
Posted on: 20 April 2017 by thebigfredc
MMS threads are excruciating and this one even more than usual.
His experience of this hobby and mine couldn't be more different.
I really, really love listening to music on a decent stereo.
Ray
@Ryder has a good point. For less than the retail price of a powerline, one could get the Nait5i....
OTOH, I just remembered - I do have a UQ2/KudosX2 in the loft. I enjoy it. :-) Sounds consistently awesome.
Anyway - couldn't figure the issue / did a rebuild on the brain side, and sound once again not thin anymore. Problem solved for now?
Posted on: 21 April 2017 by JoexNaim
...amp with tone controls Mango? I think you'll be so much happier....you could downgrade to Luxman 590ax2 and you won't stop grinning. You'll never go back to class ab.
.....oh, and you'd be downgrading to what some think is the worlds finest integrated amp.
Posted on: 21 April 2017 by hungryhalibut
When I had a Fraim I had the boxes aligned with the front of the glass, which looked and sounded very nice.
Maybe your glass is upside down. Getting it the right way up can make a very audible difference. Have you tightened the Fraim in the last year? If not, it's worth doing that too, as the legs can work loose. Are the spikes centralised so that they don't touch the walls of the cups? That also makes a difference.
Posted on: 21 April 2017 by b_lund
Get rid of the fraim and get some bamboo
Posted on: 21 April 2017 by The Strat (Fender)
I think Mango should buy some better coffee, a new cafetière, perhaps some more comfortable furniture, sit down and indulge in his best music and FORGET about the stereo.
Sorty mate
Sorty mate
Typo - meant sorry!!
Posted on: 21 April 2017 by Huge
Mango wood surely!
Posted on: 21 April 2017 by MangoMonkey
and done! System singing again.
Posted on: 22 April 2017 by Michael_B.
MM it would perhaps be helpful to others to have a summary of what you did, and whether HH's suggestions helped. They are all good pointers in my experience, though I do seem to need to tighten up my own Fraims relatively rarely...
Posted on: 22 April 2017 by Dustysox
MM do you "enjoy" any other hobbies...and how!!!
Sorry mate, couldn't resist!!!!
Dusty ducks for cover.
Posted on: 22 April 2017 by MangoMonkey
Here's what I did -
changedtge system around so that on the left it looks like this:
top to bottom: nds/552/300/<emptyshelf>.
Previously it was 552/space/nds/300.
this allows me to have the hiline higher up so it did not touch the ground, the 552 cables to hang more loosely and further apart from the nds burndies.
music is not as clear anymore - however I'm not entirely sure whether that is bad or good. It's not clear due to the addition of bass I suspect.. in which case it is good. In any event the brightnesss that I was complaining about is gone.. I'm not even sure how to describe it - its not so much that the music was bright before / just that there was too much 'noise' - the opposite of inky black dark background..
its bad when the 272/xps/250 betters the nds/552/300 in that regard...
Anyway - even the previous arrangement was fine until I fiddled around with the placement on the shelf but I couldn't get it to work properly once I had futzed with it so had to start over.
Lol! This one hobby is plenty. Any other hobby I have shall have no associated gear. :-)
Posted on: 29 April 2017 by Kevin Richardson
I collect postage stamps. Is that still a hobby?
I made my life easier when I decided not to spend millions of $ for the complete set of 19th century stamps. (As a young boy I dreamed of someday filling my album.) I now only collect variations of two stamps.
Is stamp collecting still a thing? Asking for a friend.
