nd5xs upgrade
Posted by: oferr on 22 April 2017
Hello,
I have been using sn2 + ndac
Lately, thinking about upgrading streaming fidelity by adding nd5xs to the setup.  That would be a naim dac, nd5xs on sn2.  Will appreciate your kind opinions about this combo.
Posted on: 22 April 2017 by Kevin Richardson
What are you using now as a source?
Posted on: 22 April 2017 by oferr
Hi Kevin,
I am using audioengine b1
I hve been reading almost everything, and I read that nd5xs with ndac would be much better than the ndx alone.
From the other hand, I like the sound via the ndac alone...  but then, I believe that it will be so much fun to have a streamer to make life easier... and maybe improve the quality of the sound...
Posted on: 22 April 2017 by Adam Zielinski
To the OP  - you have a similar thread active. I suggest you ask the Administrators to merge them.
Posted on: 23 April 2017 by Richard Dane
Unfortunately threads can't be merged on the new platform.  I will close this one and allow the other to continue.
