Newbie. Extension block AND Hydra?
Posted by: Colonel Mustard on 28 April 2017
New member here. I have had my Naim system (CD5X, NAC 112X, Flatcap 2X and NAP 150X) for over 10 years now and would appreciate some help from you knowledgeable chaps.
Due to the unfortunate logistics of my room I am somewhat restricted with a lack of sockets and the distance my hi-fi is situated from them. I currently use a single MK (no switch) socket with a Russ Andrews Powerkord (3 metres) into a four way Russ Andrews Silencer Block using the three factory Naim power leads. Now, for obvious reasons I want shut of the Silencer Block and Powerkord and have been scouring the web for star wired mains blocks with no filtering. During my search I stumbled upon this product which on the face of it, seems to be exactly what I want and of course, passes the all important aesthetic test.
Whilst checking out the various options, I also stumbled upon the widely lauded Grahams Hydra and am now considering replacing the Russ Andrews block AND replacing my factory leads with a 3-1 Hydra.
I accept that this setup is not ideal, but for various reasons it is what I have to work with. Now, I understand that the Hydra pwas rincipally designed to remove the need for an extension block and really speaking once the Hydra is fitted the need for a star wired block is minimized, but would the two complement one another or is it a bad idea?
What would people’s preference be out of the two?
1. Four way block and factory leads
or
2. Two way block and Hydra (my preference, from a tidiness standpoint at least)
I was hoping that I would gain a sound benefit from both the Hydra and the substituting of the mains block and lead with an unfiltered version, but I understand that two upgrades don't always equate to the same benefit that they would individually.
For clarity, I run a separate (non-Naim) headphone amplifier too, so the surplus socket in either scenario is necessary.
Thanks in advance.
Moderated Post: Unauthorised commercial link removed.
