Mu-so Bluetooth name change
Posted by: Kiwiadventure on 01 May 2017
Hi All first post
Instead of  Mu-so BT names on bluetooth can I change the names to Living Room and Bedroom?
Posted on: 01 May 2017 by hungryhalibut
My Qb is called 'kitchen' yet still shows as Muso Qb xxxx when I connect via Bluetooth.
Posted on: 01 May 2017 by Timmo1341
Yet another First World problem!! Now let me see, where did I put that Muso / SuperUniti / Statement ??!!
Posted on: 01 May 2017 by Trevor Wilson
Hi
settings - inputs - bluetooth
you shiuls be able to change the Bluetooth name there
Posted on: 01 May 2017 by Kiwiadventure
My MacBook Pro  will not a name change. Do I need to change the name on the Qb it self and how do I do this if I can.
Thanks Trevor, I didn't know you can do that. It's just a matter of changing the broadcast name under the Bluetooth input setting, via the app.
I changed to room names using Naim App settings-other settings-room name which now works on iPhones and iPads, but the name does not change under Apple bluetooth.
It's the broadcast name that needs to be changed. Once changed, make sure you press 'done' on the iPad to save the change. When I look on my phone the Qb now shows as Qb kitchen. Very clever.
