pmc 25 23
Posted by: Johnny5 on 06 May 2017
anybody got pmc 25 23 speaker what depth are they it says 330mm but mine are 256mm depth for some reason
Posted on: 06 May 2017 by GraemeH
Johnny5 posted:
With & without grille? Including/not including sockets?
Posted on: 06 May 2017 by Pcd
Don't forget the plinth measurement and grilles see PMC website.
Posted on: 06 May 2017 by Johnny5
It say depth 330mm +9mm grill.mine is 256mm +9mm grill.
Posted on: 06 May 2017 by Chag...
What discount did you get?
Chag -
3395 euro
When PMC say depth do they mean from the front lower edge to the top rear edge taking into account the slope of the speaker ?
No their are 256mm not 330 strange as website saying 330mm
It looks like bottom corner to top corner squared off would be 330 design of the tilt I reckon. Still amazing speaker.
Posted on: 06 May 2017 by ChrisH
I just measured mine Johnny5. It is as per PCD's post and your last post - 330mm from front lower edge to top rear edge if it was dropped perpendicularly to the floor.IMG_20170506_211829
Yes that's it how do you find the speakers
Posted on: 07 May 2017 by ChrisH
Good thanks! I moved from Motive 2s so these were quite a step up for me, but im really enjoying them.
Here's a link to a post of mine in Systems 2016 thread that you might find of interest:
https://forums.naimaudio.com/to...27#64781167027054227
Enjoy the music johnny5!
Posted on: 07 May 2017 by Johnny5
Yes I agree the 25/23 are brilliant had the 25 24 for a week but they are 2 powerful in the space they need to be at least 30 inches from the back wall the 23 will fit anywhere.But the 23 sound a lot more balanced so bigger is not always best.I also use atlas mavros rca and atlas ascent 2.0 speaker cables and atlas power cables plugged in to russ andrews Xblock.naim cdx2.. Xps.. Supernait 2.
