Playlist files on the Core
Posted by: Richard Choong on 09 May 2017
Hi. Can someone tell me where the files that store the playlists on the Core is located?
What is the suffix of the files? Dot what? Thanks.
Posted on: 09 May 2017 by ChrisSU
Does the Core actually store playlists like the Unitiserve does? I'm guessing it doesn't, and you just have to use the Naim app playlist system, where they are stored on the iOS or Android device.
Posted on: 09 May 2017 by Richard Choong
I believe the Core stores the playlist on the drive where the music is. My music is on the internal drive of the Core. I stand to be corrected though.
I hope you are right, as on the Unitiserve this is a better and more reliable playlist system than the app one.
