Cisco Catalyst Config
Posted by: MangoMonkey on 12 May 2017
@Simon -
Any tips/instructions on how to configure the cisco switch? I've had great acoustic results using the switch. However, there is a lag in finding the UnitiServ and/or NAS when using the switch (Maybe a upnp lag).
Thanks!
Posted on: 12 May 2017 by Simon-in-Suffolk
Hi, do you know how to log onto the switch and go into config terminal mode?
if so I can you a set of command s to setup an IGMP querier on the switch which will encourage your UPnP SSDP to be instant .. i.e. Devices will appear almost instantly on the Naim app.
Drop me an email, I can give you the script off line... probably though after weekend now.
Simon
Sent
Posted on: 13 May 2017 by MangoMonkey
Thanks!
