Pmc Twenty5 23
Posted by: Johnny5 on 14 May 2017
how long will it take to run the Twenty5 23 in?
Posted on: 14 May 2017 by leni v
If you wont like them maybe forever, but you could get used to them evevtualy.
Posted on: 16 May 2017 by Richy
Does the manual not say?
Posted on: 16 May 2017 by ChrisH
Richy posted:
Yes it does.....IMG_20170516_190539
Posted on: 16 May 2017 by hungryhalibut
The key is the +. My twenty.23s took absolutely ages. The answer is just to listen to music and enjoy it, and don't worry about running in.
Posted on: 16 May 2017 by Johnny5
After 100 hours sound superb
They will get a lot better in a few weeks, so that's something to look forward to.
Posted on: 16 May 2017 by hafler3o
Hungryhalibut posted:
Yep, ages...
And my twenty.21s take about 10 minutes to warm up (at low level listening) after which the speakers are a good 3dB louder!
Posted on: 16 May 2017 by Parlow
I got mine about six weeks ago.  I would say it takes a month or so to loosen up. It's also worth playing about with the positioning. To my ears at least I think they need less toe in that the manual says.
About 6 feet apart with some toe and 30 inches off back wall
Parlow posted:
To mine too!
Posted on: 17 May 2017 by ray sheldon
30 inches! Not CM?
Posted on: 17 May 2017 by Richieroo
My local dealers run in the pmc's by placing them front to front really close....then run speakers out of phase....this cancels out allot of base.....they then crank up the volume and let them bake over the weekend.....
Posted on: 17 May 2017 by Ardbeg10y
ray sheldon posted:
30 inches! Not CM?
Indeed quite much for front ported speakers.
Posted on: 17 May 2017 by ChrisSU
Richieroo posted:
I had always assumed that the reason for running in speakers out of phase was that the opposing drivers would then 'work' each other, and speed up the physical running in process, rather than to cancel out bass as such.
Chrissu you probably have a point .... the base drivers would get more assistance as they are mutually tracking each other in very close proximity.....hmmm
Posted on: 17 May 2017 by james n
Richieroo posted:
Quite - one speaker is run out of phase to the other and this cancels a lot of the sound output when placed facing each other. I don't think you can anything from them working against each other as the main gain comes from working the drivers surround and spider.
Posted on: 17 May 2017 by Johnny5
Yes inches
