DIN 5 pin DIN 4 pin cable for Superline setup (from SC to Pre)
Posted by: ayisgroovy on 18 May 2017
Hi everyone.  I am looking for a suggestions on the above cable.  Aside from HiLine option what do you use with your Superline setup please?  Witchhat Audio?
Posted on: 18 May 2017 by Richard Dane
The standard grey Naim 4-5 interconnect.  I prefer it to the 4-5 Hiline in this application.
Posted on: 19 May 2017 by pylod
Hi Richard, can you please explain why the grey over the Hiline ? Thank you.
Posted on: 19 May 2017 by Richard Dane
Pylod, I preferred it. A long time ago though so can't recall exact comparison details.
Posted on: 19 May 2017 by lyndon
Hi AYISGROOVY
im currently using a chord signature TA to good effect, clear difference between that and the lavender but so is the price
i will probably go to sarum as I've started this with the speaker cables got 2/3 rds of them, they are a huge difference but then so is the cost
why not experiment by buying s/h
coomon options are:
chord
tellerium
AR
witch hat
i did just that with a different type cable some time ago, it transpired that I preferred the Naim I already had so off it went to the fishy place, doubt there was more than a tenner in it either way
lyndon
Thank you Richard. I guess a lot comes to personal preferences.
Will be interesting to hear how the Sarum compares,Lyndon.
Pylod
my intention is to do a Sarum full loom
but even s/h or ex dem this represents a sizeable investment and we should be mindful, does the system warrant these high end cables
there's been a lot of posts lately discussing very expensive cables, above Sarum without the relevant black boxes in place to realise the gains from esoteric cables
I'm going for sarum on the basis
my LP12 is maxed out
the DBLs are here to stay
the 52 will go - there is only 1 upgrade here
the 6 135's will go - there is only 1 replacement for this ( albeit 3 of them )
lyndon
Posted on: 19 May 2017 by yeti42
Lavender.
I don't remember buying it and I've not bought anything that came with one in the box.
I totally understand Lyndon. I am still with all basic cables, but went for recap and dr of my 552 and 500. Going through the famous burn in rollercoaster ride right now.  Next stepp would be an own dedicated supercap dr for the superline. And that is where the 4to5pin comes in.
Looks you have an adventurous journey ahead. If i could only host some DBL at home - But still very happy with my SL2.
