Naim Uniti Core transcode FLAC to WAV
Posted by: Klout10 on 22 May 2017
Just as the title suggests: is it possible to convert FLAC files stored on the Uniti Core on the fly to WAV files? At least the old HDX could do this ... also convert from FLAC to WAV ...
Thanks for your reply!
Posted on: 22 May 2017 by David Hendon
Klout10 posted:
You can't do this at the moment. I'm not aware of whether it's on their roadmap or not, but I vaguely remember Naim saying it was for adding later.
best
Daviid
Posted on: 22 May 2017 by Klout10
Thankx David!
Posted on: 24 May 2017 by nbpf
David Hendon posted:
Klout10 posted:
best
Daviid
It is mildly annoying that the Core's UPnP server does not support transcoding. Asset can transcode, MinimServer can transcode from/to virtually any format ... what's the problem with transcoding? Why doesn't the Core's UPnP server support transcoding? Naim should first try to get their homework done. Our music collections can be reinvented later.
Posted on: 24 May 2017 by KRM
The Unitiserve transcodes, but the doesn't. Oh dear.
Keith
