Internal or external?
Posted by: Kage on 11 August 2011
Okay, copying my cd's into iTunes on my mac mini. At the moment it's playing starught into my nait xs and pumping out of my c7's. Sounds great but I can't wait to put a nDac inbetween the mini and amp.
Just quickly though, is it better to save my files (aiff) onto the mini's hard drive, or onto an external one. I gave one to hand and wondered would it help having the mac free from files. If so is it easy enough to direct iTunes music library to the external drive?
Posted on: 11 August 2011 by MartinCA
I keep my iTunes music on an external network drive - I set this under preferences/advanced.  I manage the music from my Desktop PC, but also access it wirelessly from various laptops and a macbook (but avoid adding or deleting from those).
I have no problems with this. I don't notice a performance penalty, but the network is gigabit, so I shouldn't really.It frees up a lot of space on the PC too!
Posted on: 11 August 2011 by RaceTripper
I have a MacBook Pro with a internal SSD. I keep my entire iTunes video and music library on an external 4 TB FW800 RAID 0, which is cloned on a regular basis to another identically configured RAID.
Just tell iTunes not to copy files to the iTunes Media folder when adding to the library (see Preferences->Advanced).
I ended up not streaming any of my iTunes media anyway. It sounds like rubbish, sound quality is just too disappointing.
Posted on: 12 August 2011 by Kage
Thanks guys.
As I have already started my ripping, can I finish the copying, then bung the files over to the external drive? Then link iTunes to that external drive?
Also, I have a WD Elements 320GB harddrive. Sufficient enough? Or can someone recomend something I should rather be using?
Thanks Awfully
Kage
Posted on: 12 August 2011 by RaceTripper
Originally Posted by Kage:
Thanks guys.
Thanks Awfully
Kage
You can process files anywhere you want, move them, and then tell iTunes where they are.
320GB may or may not be sufficient, depending on your needs. Look at the size of one album and multiply that by what you expect to rip. In the end 320 GB is not really that much space, and nowadays, 2 TB (i.e. (2000 GB) drives are not very expensive.
Posted on: 12 August 2011 by MartinCA
320 Gig I expect would be a little tight in time.  I started with 120 Gig and ran out of space very quickly, then I went for a 1 Ter WD Book for photos, Music and selected backups, which was running out of space, so now I have added a 2 Ter Buffalo dedicated to music.   I would start big.
I moved my music files several times, and copied subsets - I usually cleared the old iTunes library when I did that and rebuilt the entries by file/add folder to library.
I have also used a free AppleScript for moving files after they are in iTunes.
Posted on: 12 August 2011 by James L
Does the Mini have Firewire? I guess it should....?
Assuming it has FW then use a FW external drive. It's way quicker for file transfers etc but also it'll free up the USB as the connection for audio (via HighFace or Halide Bridge etc). USB, with an interface, is the preferred method vs optical. Especially if you plan on adding the nDAC.
Posted on: 12 August 2011 by garyi
Remember, data in one place is no data at all!
How true.
My 4 TB RAID 0 is actually two, the second being a backup of the first.
Posted on: 14 August 2011 by Iver van de Zand
Dear Kage, it might be slightly more complicated than this. I can definately recommend transferring everything onto an external HDD, but moving an existing iTunes library needs to be done with care. Please read: http://www.ilounge.com/index.p...new-hard-drive-2007/ . If you follow step by step, everything will run smoothly. My recommendation is to keep the Library itself on you computer's hrddsik, and have the library with the music files on your your ext hdd. Cheers,
Iver
