all web stations accessible by Uniti / UnitiCute?
Posted by: mige0 on 22 August 2011
Coming from Squeezebox I'd wonder if any of the zillion web stations are accessible by the Uniti or UnitiCute - or - am I restricted to stations pre-selected by NAIM ?
With SB there is an web interface where each and any station can be added, should I want to pick it form one of the internet radio guide pages like this :
http://www.radioguide.fm/How is this to be done with the NAIM ?
Best
Michael
Posted on: 22 August 2011 by garyi
There is the same sort of thing called vtuner i think.
Posted on: 22 August 2011 by mige0
Thanks a lot
Thats the puzzle-piece I have been missing
Michael
Posted on: 24 August 2011 by Trevor Wilson
Hi
If you go to
http://myradio.naimaudio.com
You should be able to login to the vtuner service with your mac address and then register. Once this is done, you can add stations to your own product using the "added stations"
Naim's vtuner implementation has about 1700 stations currently.
Trev
Posted on: 24 August 2011 by mige0
I did have a look at the vtuner page - but not that much to see there without login
Michael
Posted on: 26 August 2011 by mige0
is there a possibility to add Internet radio station directly with the remote control (without accessing vTuner via PC) ?
Not to store it as a preset but in the list under "added stations" ?
Michael
Posted on: 29 August 2011 by Trevor Wilson
Hi
No, it's only possible to add via web interface.
Posted on: 31 August 2011 by mige0
Too bad - thanks anyway.
Hopefully NAIM will add that in near future.
To add web stations you have selected or are listening to as such "favorites" directly via remote control and not needing to log in via PC is a very nice and comfortable feature.
I'm used to it for years now, as Squeezebox does this with no problem.
Micheal
