Naim Core !
Posted by: raykelly on 14 June 2017
After set up I have lost sound / volume everything seems ok connected via iPad to Naim DAC1
Did it work while you were setting up, or is it that you haven't had a peep from it at all?
After setup it did work but when browsing suddenly lost sound ! I have checked and re downloaded app etc with no luck everything else appears to be OK ! Thanks
NB I deleted one album before losing sound / volume
Basics first: have you tried turning the Core off and then back on again? as with any computer system -and after all that is what it is inside - it is always worth a try (when I had an ND5XS that sometimes was necessary). If that doesn't work I'll bow out and let a Core user step in.
raykelly posted:NB I deleted one album before losing sound / volume
And you are not trying to replay that album, right?
Hi,
Please be aware that we do have a dedicated support team who are there to assist anyone with issues or queries personally and can be reached on 01722 426600 or support@naimaudio.com (details in the "About this site" section on the right).
When you start something playing does the app itself indicate that playback is proceeding or is the time counter not incrementing?
Best regards
Phil Harris
Hi Phil
Thanks and to all on forum !
I have just done the classic unplug power down routine and we are back in business 1
Many Thanks again RAY K
