Uniti Core connection
Posted by: Robert Burgess on 14 June 2017
Hi - Am considering a Uniti Core connected to my NAC 272. To control it from an iPad does it need to be connected separately to my network, or can it only be connected to one of the digitally inputs on my 272? Thanks
Posted on: 14 June 2017 by ChrisSU
You can connect both devices to your network and play using UPnP, or you can connect the Core to the SPDIF input on the 272. Both will work, but the Core should have a network connection anyway.
Posted on: 15 June 2017 by Richard Dane
As this is a duplicate post, I'll close this one with the fewest replies.
